Installation & Licensing
inventor2014Ita missing file
10 REPLIES 10
Message 1 of 11
valeloru
4911 Views, 10 Replies
Hi everyone,
I downloaded the italian version of Inventor 2014.
The name of file is: Autodesk_Inventor_2014_Ita_64bit_dlm_001_002.sfx  (3,93 GB)
When I go to install it says missing files.
Where is this missing file?
Please, help me.
Thank you
10 REPLIES 10
Message 2 of 11
asburyj
in reply to: valeloru
The inventor download is broken into two parts. When you choose a browser download it should start downloading both. One should end with _001_002 and the other ends with _002_002
To save you a little trouble I have generated a direct download link to that 2nd part. You can trigger the download with the link below
http://efulfillment.autodesk.com/SWDLDNET3/2014/INVNTOR/DLM/Autodesk_Inventor_2014_Italian_64bit_dlm...
Jeffry Asbury
Message 3 of 11
valeloru
It works!!!
I downloaded the second file and there isn't the error message now! finally!
Thank you very much!!!
Have a good day.
Message 4 of 11
in reply to: asburyj
why do i need a subscribtion to down load it if it is free
Message 5 of 11
Hi I have a similar issue when attempting to dowload the enligsh language version. However I can only download part 2 (Autodesk_Inventor_2015_English_Win_64bit_R1_dlm_002_002.sfx) and do not seem to have the option to download part one.
Would you be able to provide a direct download link to Inventor part one.
Message 6 of 11
asburyj
Both parts of the English Inventor download are available on the virtual agent if needed. Here are the steps to find it the direct download links. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk... Select the 2nd Choice "Download Links " Select your product You are now presented with the choice to download your software.
Jeffry Asbury
Message 7 of 11
gabor.kleinheincz
similar isssue for me, with this file:
Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm_001_002.sfx.exe
But it seems (from the name at least "001_002") that it contains both parts...
Message 8 of 11
asburyj
in reply to: gabor.kleinheincz
The 001_002 in the file name means file 1 of 2. If you are missing part 2 you can download it from the virtual agent using the instructions posted above.
Jeffry Asbury
Message 9 of 11
please, can you post ones again link to 002 file? The preveuse one doesnt work anymore. Thanks
Message 10 of 11
asburyj
You wanted the italian version like what was originally requested in the thread? If so here's a link
Jeffry Asbury
Message 11 of 11
Oh sorry no, didnt see it! I want English please.
Thank you.
Administrator Productivity
