Installation & Licensing
Inventor viewer 2013 installation error
3 REPLIES 3
jason
2165 Views, 3 Replies
Im trying to load inventor viewer 2013 and am continually getting the following error message.
we have a piece of third party software reliant on this viewer.
Any ideas on how correct this please.
2012/6/20:16:10:28 Jasons SHEETMETAL === Setup started on SHEETMETAL by Jasons ===
2012/6/20:16:10:28 Jasons SHEETMETAL Launch
2012/6/20:16:10:32 Jasons SHEETMETAL === Setup ended ===
2012/6/20:16:10:30 Jasons SHEETMETAL === Setup started on SHEETMETAL by Jasons ===
2012/6/20:16:10:30 Jasons SHEETMETAL Launch
2012/6/20:16:10:32 Jasons SHEETMETAL Inventorui== Parameter: Prereq_6 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/6/20:16:10:32 Jasons SHEETMETAL PageOpen LaunchDialog
2012/6/20:16:10:36 Jasons SHEETMETAL PageOpen LicenseDialog
2012/6/20:16:10:43 Jasons SHEETMETAL PageOpen ProductSelectionDialog2
2012/6/20:16:10:47 Jasons SHEETMETAL PageOpen FullProgressDialog
2012/6/20:16:10:47 Jasons SHEETMETAL Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_InventorView_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/6/20:16:12:27 Jasons SHEETMETAL Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2012/6/20:16:12:27 Jasons SHEETMETAL PageOpen InstallCompleteDialog
2012/6/20:16:13:21 Jasons SHEETMETAL === Setup ended ===
2012/6/20:16:16:03 Jasons SHEETMETAL === Setup started on SHEETMETAL by Jasons ===
2012/6/20:16:16:03 Jasons SHEETMETAL Launch
2012/6/20:16:16:05 Jasons SHEETMETAL === Setup ended ===
2012/6/20:16:16:04 Jasons SHEETMETAL === Setup started on SHEETMETAL by Jasons ===
2012/6/20:16:16:04 Jasons SHEETMETAL Launch
2012/6/20:16:16:05 Jasons SHEETMETAL Inventorui== Parameter: Prereq_6 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/6/20:16:16:05 Jasons SHEETMETAL PageOpen LaunchDialog
2012/6/20:16:20:15 Jasons SHEETMETAL PageOpen LicenseDialog
2012/6/20:16:20:21 Jasons SHEETMETAL PageOpen ProductSelectionDialog2
2012/6/20:16:20:24 Jasons SHEETMETAL PageOpen FullProgressDialog
2012/6/20:16:20:24 Jasons SHEETMETAL Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_InventorView_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/6/20:16:21:56 Jasons SHEETMETAL Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
Thanks Jason
3 REPLIES 3
TravisNave
in reply to: jason
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
jason
in reply to: TravisNave
Thanks Travisnave What is the exact program I need to delete in program's and features, and can this effect any other software I am running
TravisNave
in reply to: jason
Delete .NET Framework 4 and anything related to it.  Use add/remove programs in Control Panel.  Then run the installer again.  Should go this time...  If not, let me know.
Autodesk Forums:
Administrator Productivity
