Installation & Licensing
Inventor Suite and Pro - Mixed Environment
4 REPLIES 4
321 Views, 4 Replies
Can someone confirm if is possible to purchase X seats of Inventor Suite and X seats of Inventor Pro, and, with one deployment, control which license is being consumed with the method stated here
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8793871&linkID=9242018
( http://tinyurl.com/58cbek )
Or would this not work due to there being two different serial numbers involved? If this isn't the method, is there another, assuming this is even possible?
Steve H.
4 REPLIES 4
TravisNave
Yes. This is possible. You simply either launch the Pro icon or the Suite icon and it will take the appropriate license.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks for the info...this seems so simple and straightforward. Just out of curiousity, if in fact there is only one deployment, how does it resolve between the two different serial numbers assigned to the separate Suite and Pro purchases? Is that command line switch really that "intelligent"?
Thanks.
Steve H.
TravisNave
Yes. It really is! 😄
Autodesk Forums:
Again, thanks. This is good info.
Steve H.
Administrator Productivity
