Installation & Licensing
Inventor Routed Systems 2011 will not load on Windows 7 Pro 64-bit
1 REPLY 1
smro
359 Views, 1 Reply
Every time I try to load Routed  Systems 2011 I get error 1719 Wind Installer. Windows 7 and windows installer have been working fine. This is the only software that the installer has not loaded without any trouble. What do I do to get it to load. I have 3 other standalone systems  and one network license to load.
1 REPLY 1
huliang2008
in reply to: smro
do you mean you cannot launch Inventor? encounter error 1719? could you please attach the error screen shot and Inventor setup log file in %temp% folder?
if you cannot launch Inventor, please try to right click the Inventor shortcut and select Run As Administrator to launch it. if it doesn't work for you, uninstall it, delect the Inventor relative file under [--Documents and Settings\All Users\Autodesk\AdLM] and try to install INV again.
Kevin Hu
SQA Eng
ACRD MFG
Autodesk, Inc.
Administrator Productivity
