Every time I try to load Routed Systems 2011 I get error 1719 Wind Installer. Windows 7 and windows installer have been working fine. This is the only software that the installer has not loaded without any trouble. What do I do to get it to load. I have 3 other standalone systems and one network license to load.
do you mean you cannot launch Inventor? encounter error 1719? could you please attach the error screen shot and Inventor setup log file in %temp% folder?
if you cannot launch Inventor, please try to right click the Inventor shortcut and select Run As Administrator to launch it. if it doesn't work for you, uninstall it, delect the Inventor relative file under [--Documents and Settings\All Users\Autodesk\AdLM] and try to install INV again.
