I download a student version of inventor 2011 from the website : "AutoCAD Inventor Professional Suite 2011 (English) 64-Bit"
There are 3 files for download : Part1 , Part 2 , Part 3 .
I download all of them , and start with the EXE file , but when i start to install the only option which is available to install is "content center libarary "
In help menu it is writen i should use the Configuration button " but i cant find it in the begin installation dialog box ,
"The Configure button is located in the Begin Installation dialog box. Click the drop-down arrow to select a product and then click the Configure button.".
My system : Laptop , windows 7 , 64 bit .
Please help me ...
Regards
Solved by JDMather. Go to Solution.
Did you have trial or student version installed on this machine previously?
Did you turn off anti-virus and UAC before beginning install?
Attach screen capture of the install inscreen where you are stuck.
Thanks for you fast response !
I did what ever you told me .
but i had another software from autodesk inventor( student vesrion ) , library or ... so i unistalled all the inventor group softwares and installed it again !
and It worked ! 🙂
Regards
SAra
