Hello Everyone,
I downloaded the Inventor Professional 2015 student version and got the email with Serial Number and product activation code from Autodesk. However, when I try to install the product, Inventor will not install. It only installs the Vault but not the Inventor itself.
Any suggestions?
Thanks.
Solved by TravisNave. Go to Solution.
Post the installation log file. It will help explain the failure.
Also, you don't need Vault.
Thank you. I have attached the file.
That's odd, it doesn't even seem to be trying to install Inventor. Is it crossed out before install by chance?
Exactly. In the installation flash screen, Inventor is crossed out. I cannot select it to uncross it. I could only install Vault.
That worked! I had to uninstall the Autodesk Low Resolution Material Library from the "programs and features" in control panel.
Now it is installing.
Thanks so much Travis. I really appreciate it.
