I've been trying to install Inventor Pro 2015 Student for two days now. Every time I try to, the install stops and tells me the install has failed.
My specs: Windows 7 Home Premium, Intel i5-4440, 4 GB RAM, Geforce GTX 650, 1 TB Hard Drive
The error log is attached. I'm not sure what to do at this point. Please help, and thank you in advance.
If you have Design Review installed, uninstall it. Also, you might do a custom install and only install Inventor, and not TrueView or any other associated package.
As always, make sure you install with local admin rights, UAC disabled, and anti-virus turned off.
Hi, Travis,
I have a similar problem with Win 8.1. I have also tried to only install Inventor but it still fails.
I have a Lenovo 515S with Win 8.1, 64 bit, AMD A4-5000 APU with Radeon HD Graphics, 8 GB RAM, 1 TB HD,
I have tried to install directly from the site, and to download first and then install from the HD; neither works.
If I install from the HD, do I still have to turn my anti-virus (McAffee) off?
BTW, what is UAC?
Best regards,
Anders Vedel.
UAC = User Access Control. Turn it off under Control Panel.
Do you mean User Account Control?
I have tried to disable that and the firewall and install only Inventor without the sub-programs; it still won't work.
I'm at my wit's end.
Anders.
Yes, that is what I mean. Not enough coffee this morning.
Post your installation log file.
Here is the logfile. It doesn't make much sense to me, but hopefully it does
to you. 🙂
Best regards,
Anders.
Hello @a.vedel.dk,
Could you please try the following tips for executing a successful download?:
Please also see @TravisNave's solution on how to fix 1600 errors. If the issue persists please respond to this post with further details. Thank you!
Jess is right on, as usual. As she noted, the 1603 error is due to the C++ 2012 failing to install. Check out the link she provided.
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Hi
I can't extract the inventor 2015 exe file and shows the error: "Product download consists of multiple files. At least one file id missing or has not been downloaded yet."
I dont know what to do and what is missing.
Please help
I have tried to download inventor 2015 both ways and each time it tells me that it cannot install because it is missing files. Can anyone tell me how to get around this?
Check out the following, try using the 3rd option for the Virtual Agent.
http://upandready.typepad.com/up_and_ready/2013/01
Once at the virtual agent pick on Download Links, then the product and version you wish to download.
If downloading the 64-bit version of Inventor make sure to download both Part1 and Part2.
Danny
Having a similar Issue.
Tried installing Inventor (version 2013 - 2015, same issue with all of the above) Using the Install Now or Downlad now options I recieve the install package, but noting occurs when I run the file. (not even a hanging process or anything appearing in my task manager)
Using the Browser download, the file runs, but I recieve the "at least one file is missing or hasn't been downloaded yet"
UAC is off
Firewall & Anti-virus are off
Clerared temp files
re downloaded several times,
tried various slective boot settings, nothing
Having this problem too for days and I'm due to give in an assignment in school, what the **** Autocad.
The experience with Autodesks installing for BOTH autocad and inventor has been error after error, followed by an absolutely horrendous interface which is a huge red flag to NEVER buy autocad, from now on it's solidwors, and anything NOT autodesk.
F*** you autodesk, your interface and support for users is an embarassment.
Your first post is a vulgar rant about your product not installing? If you would simply provide screen shots and installation log files, your fellow peers (like me) would be more than happy to assist you. But if you've already made the choice to switch to Solidworks, I hope you enjoy your experience. Thanks for using the Autodesk Community!
Hello All!
Here are a couple of common error messages that share that same resolution: "Connection Failure" Network Failed" and Lost Communication" are often due to local anti-virus, firewall, or the download method. The easiest way to resolve is trying a browser download. These can be found in the link below. Please select "Product Downloads" then continue t the version you need!
If you are getting a message about missing files, there maybe be more parts to the download. Please be sure to download all parts completely. They can be downloaded simultaneously, however, please only open part 1 to install when all parts have completed. It pulls information automatically from the other parts, so if it is not complete, it will result in a missing information error.
Autodesk Virtual Agent - Download Links
Please let us know if you are still having trouble. Screenshots of the error are always of most help!!
dont use chrome. use internet explorer. there is two part. this second part not appear on chrome because it use popup. use internet explorer, it will show first part and 'allow popup in this website'. always allow it. and download again. you will see second part.
Hello I am having a similar issue with the instal in my case it never launches the installer and then tells me to reboot windows
My System specs are as follows:
AMD FX-6300 overclcocked to 4.4 ghz
8 GB of RAM
Nvidia GTX 760 2GB (this is actually a protoype card from MSI long story but this might be the issue)
Windows 7 Enterprise N 64 bit
I have disabled uac and my firewall plus my antivirus it doesnt help
I have Autocad 2014 installed and 3DSMax 2014 and they run fine
