Installation & Licensing
Inventor Pro 2014 not installing
3 REPLIES 3
422 Views, 3 Replies
I downloaded the exe version first about 4 GB and when I run it it says one file missing and installer ends.
When I try installing directly from browser, it stops after downloading 100-200 mb and gives error or sometimes just hangs.
Exactly  how do I download the installer to run inventor on my workstation?
I had avast but I uninstalled it after reading forums and blogs.
I still have comodo firewall.
Can that be a problem?
any help here?
3 REPLIES 3
dembkod
sadhwani.sapna19 ,
Hello. Firewall can always be a problem. First, download from here:
  1. Go to http://www.autodesk.com
  2. At the bottom of the page, beneath "Help and Support" click "Customer Service"
  3. Click the "Ask" button for the "Virtual Agent"
  4. Once the Virtual Agent opens, click "Download Links"
  5. Select the appropriate product and download
Inventor PRO 64 bit is two files. You need to download both. If you only have one you will get the error you mention.
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
Thanks that worked.
When I am downloading from the trial page it downloads only one file for some reason but your instruction link worked and I can run it now after downloading the second part.
I have the same problem but I can't find link to Inventor proffesional 2012 or any another Inventor prossesional.
I follow your instructions but unsuccessfully
Only Inventor can download is:
please help
Administrator Productivity
