I downloaded the exe version first about 4 GB and when I run it it says one file missing and installer ends.
When I try installing directly from browser, it stops after downloading 100-200 mb and gives error or sometimes just hangs.
Exactly how do I download the installer to run inventor on my workstation?
I had avast but I uninstalled it after reading forums and blogs.
I still have comodo firewall.
Can that be a problem?
any help here?
Solved by dembkod. Go to Solution.
Hello. Firewall can always be a problem. First, download from here:
Inventor PRO 64 bit is two files. You need to download both. If you only have one you will get the error you mention.
Thank you for taking part in our community!
I have the same problem but I can't find link to Inventor proffesional 2012 or any another Inventor prossesional.
I follow your instructions but unsuccessfully
Only Inventor can download is:
please help
