Installation & Licensing
New Member
kingswolverhampton
Message 1 of 3 (192 Views)
Accepted Solution
Inventor Pro 2014 deployment for Windows 8.1 not installing
192 Views, 2 Replies
03-26-2014 05:17 AM
Hi all,
This is for use in school, the software is provided free with no end user support since there is no distributor.
When creating a 64bit deployment for Windows 8.1 the resultant deployment will not install on the end clients.
This seems to be a common problem fixed for attended installs in SP1 for alot of 8.1 issues.
However my issue is how do I create an up to date deployment that will install onto a remote 8.1 clients if SP1 is not included in creating the deployment?
Currently manually installing on 8.1 from the deployment files created fails at the progress bar around the prequesite C++ redistrubatables.
I simply need an up to do complete installer for 2014 + SP1 to create deployments from?
Thanks in advance.
I would just re-create the deployment instead of modifying it.
Product Support
david.lau
Message 2 of 3 (170 Views)
Re: Inventor Pro 2014 deployment for Windows 8.1 not installing
03-26-2014 01:02 PM in reply to: kingswolverhampton
David Lau
New Member
kingswolverhampton
Message 3 of 3 (136 Views)
04-03-2014 12:28 AM in reply to: david.lau
Yes in the end I simply recreated the deployment and investigated the customisation options to include a downloaded version of SP1.
This solved the issues.
Thanks to all responders accross email/other forums too.
Regards
Lawrence
Announcements
Need installation help?
