Installation & Licensing
Inventor Pro 2011 crashes constantly in windows Vista - help!
10 REPLIES 10
Message 1 of 11
1210 Views, 10 Replies
The amount of times Inventor crashes in unbearable, I have stopped sending error reports as they are not helpful and I am unable to send the files they request as they are not supported by windows live email.  Has anyone else had this problem? Please help me!
Thank you,
Cameron.
10 REPLIES 10
Message 2 of 11
We need more information.
What is your hardware (CPU, Memeory, video card...) and your software (OS...) ?
Have you a message when Inventor crash ?
Best regards.
Message 3 of 11
My specs;
HP Pavilion dv6700 Notebook PC
Intel Core 2 Duo CPU T9300 @ 2.5GHz
2.0GB RAM
32 - Bit operating system
I am using the 32 bit Inventor version.
When the program crashes it comes up with the standard error report asking me to send autodesk the information via email.  Is there anything else you need to know?
Thanks again,
Cameron.
Message 4 of 11
Mark_Wigan
cameron,
    do you have the service pack installed for your inventor,
...are you maxed out on cpu and ram whiile you are working (your specs are a bit low but depends if you are only working on one or two parts you hsould be ok).
...are the crashes ocuring only at times when you are trying to carry out specific operations (eg during edit sketch in idw etc).
...make sure your application options / hardware is set to compatibility if you have old hardware. your graphics won't be able to push inventor otherwise.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Message 5 of 11
in reply to: Mark_Wigan
I do not believe my CPU is at max, tonight i successfully ran Safari (on Windows PC) while on Inventor.  Inventor did not crash until I left my mouse above the 'Arc' function (I think it was) and it tried to load the video illustrating what it is.  The program then froze briefly and crashed.
I have a Nvidia graphics card if that helps.
Message 6 of 11
Could you give us the Product number of your HP Pavillion ?
You will find this information where you have your HP serial number.
If you didn't find it, what is your video card ?
What type of object are you making ? Just one part or an assembly ?
Message 7 of 11
Mark_Wigan
i read another post today related to crash when clicking on a particular ribbon icon (which spoke about that being fixed in a service pack or hot fix),
the post went on to discuss other possibilities such as 3dconnexion mouse drivers which that particular user was speaking of.
visit the autodesk subscription site and search the support area for downloads perhaps?
does the crash happen randomly or only when hovering on the ribbon?
visit nvidia and download the latest display drivers (sorry if you did that already i couldn't recall)
try going to your control panel \ nvidia control panel and in the 3d settings check if inventor is able to be configured under programs. if so turn off vertical sync.
in your application options, drawing tab, select memory saving mode, and in your display tab, settings, deselect any shading options (if you are in 2011 that is, again apologies if you are not).
best regards,
- Mark
Message 8 of 11
Be more explicit on what type of Nvidia card you have .
What is the version of the driver you have ? Perhaps made an upgrade of it.
Message 9 of 11
Product Number: FE076PA#ABG
NVIDIA Graphics Card: NVIDIA GeForce 8400M GS
Current Installed driver: 187.66
I am currently installing Version 260.99, which hopefully will help .
I went to NVIDIA control panel and turned 'Vertical Sync' to 'Force off'
I also changed the 3D settings from Highest quality to balanced between performance and quality.
The program, I believe crashes mostly when hovering over a ribbon.  Can i turn off the drop down bars from ribbon icons?
Thanks again,
Cameron
Message 10 of 11
Mark_Wigan
yes you can compact your ribbon and turn off tips and clips (the right side of the ribbon there is a small arrow drop down you can right click on...)
see how that goes.
best regards,
- Mark
Message 11 of 11
Mark_Wigan
your question on the ribbon = yes you can compact your ribbon and turn off tips and clips (the right side of the ribbon there is a small arrow drop down you can right click on...)
see how that goes.
best regards,
- Mark
Administrator Productivity
