Installation & Licensing
Inventor & MDT 2008 License
4 REPLIES 4
321 Views, 4 Replies
I am running Inventor 2008 with no problem using a network license. However, when I try to use MDT 2008 from the same machine, MDT can't find a license. No other users are using either program. Does an additional license need to be purchased for MDT 2008?
4 REPLIES 4
BTW, the error message says Error[1.5.-18]
TravisNave
Did you upgrade your NLM to 11.4 for this version? Also, you may need to set your environment variables. MDT2008 uses the exact same license as your AIS2008, so the problem is likely connectivity somewhere.
-18 License server system does not support this feature.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
The only related enviromental variable that I'm aware of is the variable ADSKFLEX_LICENSE_FILE. Are there others that I should look into?
TravisNave
Yes, you might consider the FLEXLM_TIMEOUT of 1000000.
Autodesk Forums:
Administrator Productivity
