Installation & Licensing
Inventor LT 2014 Trial Version Failed to Install Due to Network Failure
3 REPLIES 3
2674 Views, 3 Replies
Hello everyone,
I was able to download the trial version of Inventor LT 2014, but when it automatically run, installation of the Akamai NetSession Interface failed, it tells me that I have a 'Network Failure'.  For the Inventor LT 2014, there is only the 'install now' option, so I use this option to download.
Before I downloaded it, I did turned off my UAC, anti-virus, Windows Firewall and I also downloaded Microsoft .NET Framework 4.5.  Could it be that my computer does not meet the system requirements for this software?  See image of my system (Lenovo H330).
Is there a way, I can run the Setup.exe without meeting 'Network Failure'?
After that, I see that it was partially installed on my computer, so I try to run the Setup. exe as an adminstrator, but my computer tells me that there is a 'Communication Failure' due to it has lost connection with the Autodesk site or I need to try installing again as 'install now' or browser download'.
Thank you,
Ben
3 REPLIES 3
TravisNave
This issue has been plaguing the community as of late.  I wrote a post about it here:
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
You can download direct here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hey Travis,
Thank you very much for your help.
I was able to successfully installed it.
Take Care,
Ben
I am still getting the network failure message when downloading autodesk inventor 2015 trial version. Can you help me please?
Administrator Productivity
