Installation & Licensing
Member
CWBen
Message 1 of 4 (1,352 Views)
Inventor LT 2014 Trial Version Failed to Install Due to Network Failure
1352 Views, 3 Replies
01-14-2014 05:47 PM
Hello everyone,
I was able to download the trial version of Inventor LT 2014, but when it automatically run, installation of the Akamai NetSession Interface failed, it tells me that I have a 'Network Failure'.  For the Inventor LT 2014, there is only the 'install now' option, so I use this option to download.
Before I downloaded it, I did turned off my UAC, anti-virus, Windows Firewall and I also downloaded Microsoft .NET Framework 4.5.  Could it be that my computer does not meet the system requirements for this software?  See image of my system (Lenovo H330).
Is there a way, I can run the Setup.exe without meeting 'Network Failure'?
After that, I see that it was partially installed on my computer, so I try to run the Setup. exe as an adminstrator, but my computer tells me that there is a 'Communication Failure' due to it has lost connection with the Autodesk site or I need to try installing again as 'install now' or browser download'.
Thank you,
Ben
This issue has been plaguing the community as of late.  I wrote a post about it here:
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-1603/td-p/4716025
You can download direct here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
TravisNave
Message 2 of 4 (1,328 Views)
Re: Inventor LT 2014 Trial Version Failed to Install Due to Network Failure
01-15-2014 12:09 PM in reply to: CWBen
Member
CWBen
Message 3 of 4 (1,314 Views)
01-15-2014 04:56 PM in reply to: TravisNave
Hey Travis,
Thank you very much for your help.
I was able to successfully installed it.
Take Care,
Ben
New Member
daking3
Message 4 of 4 (662 Views)
07-01-2014 03:37 PM in reply to: TravisNave
I am still getting the network failure message when downloading autodesk inventor 2015 trial version. Can you help me please?
