Installation & Licensing
inventor keeps crashing!
2 REPLIES 2
470 Views, 2 Replies
I installed inventor pro 2013 edu ed as part of the product design suite  4 weeks ago.  Everything seemed to intall correctly however, three of the applications crash.  Revit and Showcase and Inventor.
In the case of inventor, I open the app from short cut, choose new part, create and it crashes.
Running XP Professional sp3
AMD Phenom II X6 1090T
3.21GHz, 3.25 GB of RAM
NVIDIA  Ge 9800 graphics card.
Not getting any support from the autodesk techs who receive my crash report.  All ask for "files" but not description of what files they want.  I've provided on numerous times the step by step sequence leading to the crash.  But they keep asking for "files".
Can I completely uninstall all the autodesk student apps with product design suite and reinstall?  I've been told that the student version only allows 1 install.
HELP!!!
2 REPLIES 2
TravisNave
Try updating your video driver to the latest WHQL certified driver here:
http://www.nvidia.com/object/winxp-310.90-whql-driver.html
Then make sure that your product is up-to-date with all the latest fixes.
SP1.1.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20442029&linkID=9242019
Update 1 for SP1.1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20857064&linkID=9242019
You might also consider adding the /3GB switch to Windows XP to maximize your memory usage.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9583842&linkID=9240617
Good Luck!
Autodesk Forums:
Nice try Travis and thanks for the response.  But none of this worked
Administrator Productivity
