See this : (Bug in MSI 2.0)
Try the Workaround.
http://support.microsoft.com/kb/316309/en-us
Franck Hervet
www.aricad.fr
a écrit dans le message de news:
5317421@discussion.autodesk.com...
Hi, I've found this error while installing Inventor. Any ideas on solving
this?
Log -
[9/5/2006 10:45:25] === Installation started on IAN by Bec Ian ===
[9/5/2006 10:45:25] [Info] Windows Installer upgrade is not required
[9/5/2006 10:45:25] System Version = 3.1.4000.2435
[9/5/2006 10:45:25] Installation skipped: MSI Runtime 3.0
[9/5/2006 10:45:25] [Info] .NET Framework Runtime upgrade is not required
[9/5/2006 10:45:25] System Version = 2.0.50727.42
[9/5/2006 10:45:25] Installation skipped: .NET Framework Runtime 1.1
[9/5/2006 10:45:25] Installation skipped: .NET Framework Runtime 1.1 SP1
[9/5/2006 10:45:25] [Info] MDAC upgrade is not required
[9/5/2006 10:45:25] System Version = 2.81.1117.0
[9/5/2006 10:45:25] Installation skipped: MDAC 2.7
[9/5/2006 10:45:25] Installation started: Microsoft WSE 2.0 Runtime
[9/5/2006 10:45:25] Command = msiexec /i
"D:\autoinventor\support\wse\Microsoft WSE 2.0 Runtime.msi" /L*v
C:\DOCUME~1\BECIAN~1\LOCALS~1\Temp\WSE20_setupLog.log /qb
[9/5/2006 10:45:27] [Error: 1619] This installation package could not be
opened. Verify that the package exists and that you can access it, or
contact the application vendor to verify that this is a valid Windows
Installer package.
[9/5/2006 10:45:27] Installation failed: Microsoft WSE 2.0 Runtime
[9/5/2006 10:45:27] Installation aborted
[9/5/2006 10:45:28] === Installation ended ===
I dont seem to understand the problem... Thx guys
