Hi gusy,
I got Inventor Pro 2014 and the GTX 660 card. When I run inventor to activate it, it would freeze.
I had read about a similar problem here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodes... they suggest to "Run with Graphics processor", but I don't have it, when I right-click the icon.
Tried also tips from here http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
without any results.
If I would boot in safe mode, inventor would simply hold the loading window for a few seconds and close.
What would you suggest?
Thanks guys.
R
I just formatted the primary SSD, disconnected the secondary and installed fresh windows 7, 64bit. Still the same, freezes when loading.
in the INVPROSA2014ENUAdlm.log file I get this.
1232 2014/06/24 14:14:54 Reason=Fatal error
1232 2014/06/24 14:14:54 ComputerName=ROBERT-PC
1232 2014/06/24 14:14:54 OS=6.1.7600.
1232 2014/06/24 14:14:54 File=AdlmIntSATSLicense.cpp,Line=474
1232 2014/06/24 14:14:54 VendorID=2 [ADLMACT]
1232 2014/06/24 14:14:54 VendorError=101 [The license cannot be accessed/loaded/opened]
when I removed the file
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
( as suggested here http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/AutoCAD-2011-crashes-immediately/td-p/2787094 )
the loading windows just poped up and disappeared, without freezing. in the log file I get this
5028 2014/06/24 18:21:03 Reason=Fatal error
5028 2014/06/24 18:21:03 ComputerName=ROBERT-PC
5028 2014/06/24 18:21:03 OS=6.1.7600.
5028 2014/06/24 18:21:03 File=AdlmIntLicenseMgr.cpp,Line=447
5028 2014/06/24 18:21:03 VendorID=6 [ADLMPIT]
5028 2014/06/24 18:21:03 VendorError=24 [Unable to locate the Product Information Table File]
5028 2014/06/24 18:21:03 File=AdlmIntLicenseMgr.cpp,Line=448
5028 2014/06/24 18:21:03 AdlmIntError=41 [Product Information Table file is not found]
5028 2014/06/24 18:21:03 File=AdlmIntLicense.cpp,Line=590
5028 2014/06/24 18:21:03 File=AdlmIntLicense.cpp,Line=591
but once reinstalled again, the old freezing continues.
yet in C:\ProgramData\FLEXnet i see adskflex_00691b00_event.log , which has
20:15:38 24-06-2014 [P:1440],[T:1772] EventCode: 20000009, Message: The service is incorrectly configured, reinstall
20:15:38 24-06-2014 [P:1440],[T:1772] Exception: 59, Module: f0000, Location: 10
