I'm having trouble getting my 2014 Inventor installation to behave as described here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17437350&linkID=9242018
Based on the article above, I was expecting that even though I have the Factory version of Inventor installed it would grab a PDSP license. Only when I click on a Factory feature within Inventor would it go to the FDSP license.
Am I misinterpreting the way this should work? Have I missed a step? Any suggestions?
Scott
Solved by DarrenP. Go to Solution.
according to this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21379174&linkID=9242018&CMP=OTC-RSS...
inventor grabs a factory premium license first then grabs product premium
DarrenP
in 2012 it was the other way
for an unknown reason autodesk changed the order in 2013 & 2014
DarrenP
OK, that makes more sense now. And when did Inventor Professional move from PDSU to PDSP? Was that this year?
yes it was
DarrenP
@DarrenP wrote:in 2012 it was the other way
now that i think about it
2013 product design suite premium added inventor routed systems this was probably the reason for the switch
DarrenP
DarrenP
So, if FDSP is now lowest on the totem pole, that's where the licenses are going to get pulled first, correct?
And would that be true from a machine that had Inventor Professional installed from a PDSP image as well? Or would that machine skip over the FDSP license and go right to the PDSP license?
when you first launch inventor it will grab the factory dsp license
then when you swtich to the lets say cable and harness enviroment it will return the fdsp and grab prdsp license
DarrenP
Hi I have a similar problem.
I have FDSP and PDSU licences. I usually work with Factory licence on the factory iam template (to be honest I'm not useing factory assets at all).
Sometimes factory license is not available and when I open some iam based on facory layout Inventor gets crazy. In 2013 I would ask for a factory licence only when I was trying to change something in factory properties.
Now in 2014 it prompt me every 3 sec "Valid licence could not be obtained by the network manager" no matter what I'm doing. Its very annoing. I removed all stuff that was placed using factory "addin", didn't helped. I don't have AutoCAD file related to my iam file so it's not trying to update something.
What can I do to work on Factory iam file with PDSU licence?
-4 means Licensed number of users already reached.
DarrenP
Thanks for reply,
My case is when I have valid Plant license and I'm out of Factory licences. When I open a Factory file Inventor is trying to get Factory license which is unavailable. Why he would do that?
Please read my post on first page on this thred before you will post something like "there is no license left" or "you need factory license". I did not need factory license to work in factory layout file in Inventor 2013.
