Installation & Licensing
Inventor 2015 won't reinstall, language pack is blocking
9 REPLIES 9
Message 1 of 10
5668 Views, 9 Replies
Hi all,
First, I downloaded and installed Inventor 2015. Since I had some problems with using it I decided to reinstall it. The problem was that Inventor after opening froze. Inventor was not unresponsive but the canvas was white and nothing happened. I was able to use Inventor only once.
After uninstalling Inventor, I wanted install it again but Inventor is an inactive choice now (see the attachment). It says something about the language pack being already installed and I have been cleaning all related folders whole day and I cannot fix it.
Any ideas?
9 REPLIES 9
Message 2 of 10
DannyHubbard
You should be able to use the Microsoft Fix It utility to uninstall the language pack.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Danny
Danny Hubbard
QA Analyst
Message 3 of 10
in reply to: DannyHubbard
I used that but after reinstalling and I couldn't find any language pack or
anything related to Autodesk.
Message 4 of 10
DannyHubbard
The other thing you could try is running the following from a Command Prompt in Windows, then choose Yes to uninstall the product.
MsiExec.exe /X{7F4DD591-1964-0001-1033-7107D70F3DB4}
Danny
Danny Hubbard
QA Analyst
Message 5 of 10
Danny,
After executing this command some uninstallation was performed but it still
says that the language pack is blocking Inventor from getting installed.
I also cleaned up the registry. Any ideas?
Krzysztof
Message 6 of 10
DannyHubbard
Krzysztof,
The best thing is to use the Microsoft Fix it utility mentioned previously.
I prefer to use the optioin to Let me select the fixes, then choose Uninstalling and look for an Autodesk Inventor 2015 <language> Language Pack entry and choose Next to remove the entry.
Danny
Danny Hubbard
QA Analyst
Message 7 of 10
Danny,
It was not on the list provided by Microsoft Fix it so I chose 'not listed' and used {7F4DD591-1964-0001-1033-
7107D70F3DB4} (i.e. what you sent me before). It solved the problem.
Thank you very much!
Krzysztof
Message 8 of 10
yo tengo el mismo problema con 2014 y no e podido solucionarlo
Message 9 of 10
thanks so much for your help. its work god bless you
Message 10 of 10
me2201056
Thanks man you heleped me lot.
Administrator Productivity
