I've tried downloading Inventor 2015 several times, but I keep getting the same results. I've tried the install now, download now, and browser download but nothing is working. Here is a screen shot of what I'm getting and below it is the installation log file. Please help!
2014/8/29:12:51:52 Gregory JARVIS === Setup started on JARVIS by Gregory ===
2014/8/29:12:51:52 Gregory JARVIS Path_Length: 155
2014/8/29:12:51:52 Gregory JARVIS Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US
2014/8/29:12:51:52 Gregory JARVIS Launch
2014/8/29:12:51:52 Gregory JARVIS CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49650768 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/29:12:51:52 Gregory JARVIS Current Directory C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp
2014/8/29:12:51:58 Gregory JARVIS === Setup ended ===
2014/8/29:12:51:55 Gregory JARVIS === Setup started on JARVIS by Gregory ===
2014/8/29:12:51:55 Gregory JARVIS Path_Length: 155
2014/8/29:12:51:55 Gregory JARVIS Current Directory C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp
2014/8/29:12:51:55 Gregory JARVIS Launch
2014/8/29:12:51:56 Gregory JARVIS Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6...
2014/8/29:12:51:56 Gregory JARVIS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:51:56 Gregory JARVIS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/29:12:51:58 Gregory JARVIS PageOpen LaunchDialog
2014/8/29:12:52:08 Gregory JARVIS Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:52:08 Gregory JARVIS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/29:12:52:08 Gregory JARVIS Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/8/29:12:52:08 Gregory JARVIS Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:52:08 Gregory JARVIS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/8/29:12:52:08 Gregory JARVIS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/8/29:12:52:30 Gregory JARVIS PageOpen LicenseDialog
2014/8/29:12:52:30 Gregory JARVIS PageOpen ProductInfoDialog
2014/8/29:12:52:30 Gregory JARVIS PageOpen InventorFlavorSelectionDialog
2014/8/29:12:52:30 Gregory JARVIS Inventorui==DefaultLanguage: en-us
2014/8/29:12:52:30 Gregory JARVIS Inventorui==InstallName: INVENTOR
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ProductName: Autodesk Inventor 2015
2014/8/29:12:52:30 Gregory JARVIS Inventorui==DisplayName: Autodesk® Inventor® 2015
2014/8/29:12:52:30 Gregory JARVIS Inventorui==DeploymentName:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SetupTitle: Autodesk Inventor 2015
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ConfigTransform:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ExeParams:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4}
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SupportLink:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==InfotainmentLink:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==MsiFileName: inventor.msi
2014/8/29:12:52:30 Gregory JARVIS Inventorui==AdminImageConfigName: Imgx64
2014/8/29:12:52:30 Gregory JARVIS Inventorui==AdminImageRoot:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==GetBaseDeploymentName:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==DeploymentLocation:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu
2014/8/29:12:52:30 Gregory JARVIS Inventorui==InstallDeploymentShortcut:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ModifyDeploymentShortcut:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SetupLockType: 2
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SetupNetworkType: 1
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SystemLocale: 1033
2014/8/29:12:52:30 Gregory JARVIS Inventorui==EvalMsiFilePath: C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\SetupRes\eval.msi
2014/8/29:12:52:30 Gregory JARVIS Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA
2014/8/29:12:52:30 Gregory JARVIS Inventorui==InstallLogPath: C:\Users\Gregory\AppData\Local\Temp\Inventor2015Install.log
2014/8/29:12:52:30 Gregory JARVIS Inventorui==ConfigFile: C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup.ini
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SetupPath: C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\
2014/8/29:12:52:30 Gregory JARVIS Inventorui==NetworkLogPath:
2014/8/29:12:52:30 Gregory JARVIS Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015
2014/8/29:12:52:32 Gregory JARVIS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/8/29:12:52:32 Gregory JARVIS PageOpen ProductSelectionDialog2
2014/8/29:12:52:56 Gregory JARVIS PageOpen FullProgressDialog
2014/8/29:12:52:57 Gregory JARVIS Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST...
2014/8/29:12:52:57 Gregory JARVIS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gregory\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/8/29:12:53:57 Gregory JARVIS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
I would start here:
If that doesn't work, you can modify the setup.ini file to ignore the error accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
