Installation & Licensing
Inventor 2015 is failing to install on my laptop
3 REPLIES 3
645 Views, 3 Replies
I've tried downloading Inventor 2015 several times, but I keep getting the same results. I've tried the install now, download now, and browser download but nothing is working. Here is a screen shot of what I'm getting and below it is the installation log file. Please help!
2014/8/29:12:51:52    Gregory    JARVIS    === Setup started on JARVIS by Gregory ===
2014/8/29:12:51:52    Gregory    JARVIS    Path_Length: 155
2014/8/29:12:51:52    Gregory    JARVIS    Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US
2014/8/29:12:51:52    Gregory    JARVIS    Launch
2014/8/29:12:51:52    Gregory    JARVIS    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49650768 /PK 797G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/29:12:51:52    Gregory    JARVIS    Current Directory C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp
2014/8/29:12:51:58    Gregory    JARVIS    === Setup ended ===
2014/8/29:12:51:55    Gregory    JARVIS    === Setup started on JARVIS by Gregory ===
2014/8/29:12:51:55    Gregory    JARVIS    Path_Length: 155
2014/8/29:12:51:55    Gregory    JARVIS    Current Directory C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp
2014/8/29:12:51:55    Gregory    JARVIS    Launch
2014/8/29:12:51:56    Gregory    JARVIS    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6...
2014/8/29:12:51:56    Gregory    JARVIS    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:51:56    Gregory    JARVIS    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/29:12:51:58    Gregory    JARVIS    PageOpen    LaunchDialog
2014/8/29:12:52:08    Gregory    JARVIS    Install    CustomCallback    Info    Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:52:08    Gregory    JARVIS    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/29:12:52:08    Gregory    JARVIS    Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/8/29:12:52:08    Gregory    JARVIS    Install    CustomCallback    Info    Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup\InventorUI.dll
2014/8/29:12:52:08    Gregory    JARVIS    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/8/29:12:52:08    Gregory    JARVIS    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/8/29:12:52:30    Gregory    JARVIS    PageOpen    LicenseDialog
2014/8/29:12:52:30    Gregory    JARVIS    PageOpen    ProductInfoDialog
2014/8/29:12:52:30    Gregory    JARVIS    PageOpen    InventorFlavorSelectionDialog
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==DefaultLanguage:    en-us
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==InstallName:    INVENTOR
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ProductName:    Autodesk Inventor 2015
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==DisplayName:    Autodesk® Inventor® 2015
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==DeploymentName:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SetupTitle:    Autodesk Inventor 2015
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ConfigTransform:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ExeParams:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ProductCode:    {7F4DD591-1964-0001-0000-7107D70F3DB4}
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SupportLink:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==InfotainmentLink:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==MsiFileName:    inventor.msi
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==AdminImageConfigName:    Imgx64
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==AdminImageRoot:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==GetBaseDeploymentName:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==DeploymentLocation:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==DocumentLink:    http://autodesk.com/inventor-install-2015-enu
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==InstallDeploymentShortcut:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ModifyDeploymentShortcut:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SetupLockType:    2
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SetupNetworkType:     1
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SystemLocale:    1033
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==EvalMsiFilePath:    C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\SetupRes\eval.msi
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==EulaPath:    C:\Autodesk\WI\Autodesk Inventor 2015\EULA
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==InstallLogPath:    C:\Users\Gregory\AppData\Local\Temp\Inventor2015Install.log
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==ConfigFile:    C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\Setup.ini
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SetupPath:    C:\Users\Gregory\AppData\Local\Temp\_AI7134.tmp\
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==NetworkLogPath:
2014/8/29:12:52:30    Gregory    JARVIS    Inventorui==SourceRoot:    C:\Autodesk\WI\Autodesk Inventor 2015
2014/8/29:12:52:32    Gregory    JARVIS    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/8/29:12:52:32    Gregory    JARVIS    PageOpen    ProductSelectionDialog2
2014/8/29:12:52:56    Gregory    JARVIS    PageOpen    FullProgressDialog
2014/8/29:12:52:57    Gregory    JARVIS    Download    Skipped    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST...
2014/8/29:12:52:57    Gregory    JARVIS    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gregory\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/8/29:12:53:57    Gregory    JARVIS    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
3 REPLIES 3
TravisNave
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
I would start here:
http://upandready.typepad.com/up_and_ready/2012/09/error-1603-microsoft-visual-c-2005-sp1-redistribu...
If that doesn't work, you can modify the setup.ini file to ignore the error accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
in reply to: TravisNave
I have tried nearly every suggestion I've found, including the ones you posted. It still does not work. I tried downloading it on my desktop and it works, but not my laptop. How could I compare my desktop and laptop and see what is making the difference?
freyer
TravisNave referres to http://upandready.typepad.com/up_and_ready/2012/09/error-1603-microsoft-visual-c-2005-sp1-redistribu... This page suggest something simple as md C:\Temp to accommodate the requirements of the nine years old Microsoft Visual C++ 2005 SP1. That was all it took me. Installation in progress (way past the initial problem) as I write.
Administrator Productivity
