I have 3 computers with Inventor 2013 installed (3 standalone licenses) and also with Product Design Ultimate 2013 installed (1 network license). This worked fine - users could work on Inventor 2013 and also Product Design Ultimate 2013 software... However we are now moving to inventor 2014 on these PCs. The problem is that after installing Inventor 2014 (standalone license) user can't run any program from Product Design Ultimate 2013 bundle (network licensed) - error attached. The question is if there is any way to use Product Design Ultimate 2013 (network licensed) along with the Inventor 2014 standalone (on the same PC)?
Solved by dembkod. Go to Solution.
This message is associated with a reregistering of DLLs, not actual licensing, and it is for the simulation products. The Simulation products will display this message if you switch between years. This is the system re-registering dlls to match the program version. Most users simply upgrade to the latest Simulation version and uninstall the old.
Otherwise you need to re-register each year you switch. This error message is appearing when you start which products? It should only be simulation.
Thank you for taking part in our community!
