I am trying to download and install Autodesk Inventor 2014 (Student), and the wizard always gets stuck on the Autodesk Cloud Sync phase, and the progress bar says "Connecting." The install does not fail or abort, it just doesn't go any farther. Is there a way that I can not install the Cloud feature? Or do I have to?
Any help is appreciated.
Thanks.
Hello!
How long have you let the process stay at connecting before exiting? Are you using the Install Now delivery method? If so, is there any difference if you select Browser Download?
Cloud Sync is not configurable during the install, but here is some additional information on disabling the feature once installed.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
I let it try to connect for at least 8 hours. I left home at 7:50 and got home at 4. I am trying the browser download now, I will advise if that works.
Much appreciated!
