Installation & Licensing
inventor 2014 - failing to install content library error 1603?
5 REPLIES 5
2241 Views, 5 Replies
 Im having trouble trying to install my content library for inventor 2014. I've previously had inventor 2013 running fine on the system, and ive uninstalled and deleted everything 2013 based, or so i think. ive also tried reinstalling 2014 several times, full and just content library and deleting all previous folders of the content library whilst doing so to no avail. im in need of a fix and pretty soon as i need the content library for my work.
everything works fine its just the content lib is failing to install. this is also a local based installation with no vault.
i enclose an installation log file of the error, which it is giving me a code of 1603 i beleive?
Spoiler
2013/10/18:16:29:10    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/10/18:16:29:10    Spunky    SPUNKY-PC    Path_Length: 182
2013/10/18:16:29:10    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/10/18:16:29:10    Spunky    SPUNKY-PC    Launch
2013/10/18:16:29:10    Spunky    SPUNKY-PC    CommandLine
2013/10/18:16:29:10    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI1041.tmp
2013/10/18:16:29:20    Spunky    SPUNKY-PC    === Setup ended ===
2013/10/18:16:29:14    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/10/18:16:29:14    Spunky    SPUNKY-PC    Path_Length: 182
2013/10/18:16:29:14    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI1041.tmp
2013/10/18:16:29:14    Spunky    SPUNKY-PC    Launch
2013/10/18:16:29:16    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AI1041.tmp\Setup\InventorUI.dll
2013/10/18:16:29:16    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/18:16:29:19    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/10/18:16:29:19    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/10/18:16:29:21    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/10/18:16:29:24    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/10/18:16:29:27    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:18:37:33    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:18:37:33    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:18:37:33    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:18:37:33    Spunky    SPUNKY-PC    Launch
2013/11/11:18:37:33    Spunky    SPUNKY-PC    CommandLine
2013/11/11:18:37:33    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI2F2D.tmp
2013/11/11:18:37:46    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:18:37:39    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:18:37:39    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:18:37:39    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI2F2D.tmp
2013/11/11:18:37:39    Spunky    SPUNKY-PC    Launch
2013/11/11:18:37:40    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AI2F2D.tmp\Setup\InventorUI.dll
2013/11/11:18:37:40    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/11:18:37:44    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:18:37:44    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:18:37:46    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:18:38:02    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2013/11/11:18:38:02    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:18:38:05    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:18:38:13    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:18:38:14    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:18:38:16    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:18:38:17    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:18:38:19    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:18:38:19    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:18:38:20    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:18:38:22    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:18:38:27    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:18:38:27    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:18:44:31    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:19:00:46    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:19:00:46    Spunky    SPUNKY-PC    Launch
2013/11/11:19:00:46    Spunky    SPUNKY-PC    CommandLine    /P {7F4DD591-1864-0001-0000-7107D70F3DB4} /M INVENTOR /LANG en-US
2013/11/11:19:00:49    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:19:00:47    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:19:00:47    Spunky    SPUNKY-PC    Launch
2013/11/11:19:00:49    Spunky    SPUNKY-PC    PageOpen    MaintenanceDialog
2013/11/11:19:00:57    Spunky    SPUNKY-PC    PageOpen    MaintVerifyReadyDialog
2013/11/11:19:00:59    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/11:19:00:59    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:08:21    Spunky    SPUNKY-PC    Reinstall/uninstall     Autodesk® Inventor® 2014 ({7F4DD591-1864-0001-1033-7107D70F3DB4})    Succeeded
2013/11/11:19:08:21    Spunky    SPUNKY-PC    Uninstall    Autodesk® Inventor® 2014    Succeeded
2013/11/11:19:08:22    Spunky    SPUNKY-PC    PageOpen    MaintCompleteDialog
2013/11/11:19:10:28    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:19:14:14    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:19:14:14    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:19:14:14    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:19:14:14    Spunky    SPUNKY-PC    Launch
2013/11/11:19:14:14    Spunky    SPUNKY-PC    CommandLine
2013/11/11:19:14:14    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp
2013/11/11:19:14:26    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:19:14:19    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:19:14:19    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:19:14:19    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp
2013/11/11:19:14:19    Spunky    SPUNKY-PC    Launch
2013/11/11:19:14:20    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\Setup\InventorUI.dll
2013/11/11:19:14:20    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/11:19:14:25    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:19:14:25    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:19:14:26    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:19:14:56    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:19:15:01    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:19:20:53    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==DefaultLanguage:    en-us
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==InstallName:    INVENTOR
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ProductName:    Autodesk Inventor 2014
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==DisplayName:    Autodesk® Inventor® 2014
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==DeploymentName:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SetupTitle:    Autodesk Inventor 2014
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ConfigTransform:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ExeParams:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ProductCode:    {7F4DD591-1864-0001-0000-7107D70F3DB4}
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SupportLink:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==InfotainmentLink:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==MsiFileName:    inventor.msi
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==AdminImageConfigName:    Imgx64
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==AdminImageRoot:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==GetBaseDeploymentName:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==DeploymentLocation:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==DocumentLink:    http://autodesk.com/wikihelp-inventor-install-2014-enu
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==InstallDeploymentShortcut:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ModifyDeploymentShortcut:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SetupLockType:    2
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SetupNetworkType:     1
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SystemLocale:    2057
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==EvalMsiFilePath:    C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\SetupRes\eval.msi
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==EulaPath:    C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\EULA
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==InstallLogPath:    C:\Users\Spunky\AppData\Local\Temp\Inventor2014Install.log
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==ConfigFile:    C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\Setup.ini
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SetupPath:    C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==NetworkLogPath:
2013/11/11:19:20:53    Spunky    SPUNKY-PC    Inventorui==SourceRoot:    C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\
2013/11/11:19:20:58    Spunky    SPUNKY-PC    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/11/11:19:20:58    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:19:21:29    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/11:19:21:29    Spunky    SPUNKY-PC    Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/11:19:22:15    Spunky    SPUNKY-PC    Install    DirectX® Runtime    Succeeded
2013/11/11:19:22:17    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014:  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\x64\en-us\Inventor\inventor.mst;C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:36:14    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® 2014    Succeeded
2013/11/11:19:36:16    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014 Language Pack:  TRANSFORMS="C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\_laEB41.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:40:01    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® 2014 Language Pack    Succeeded
2013/11/11:19:41:05    Spunky    SPUNKY-PC    Install    Edu update for Inventor 2014 (DL21987424)    Succeeded
2013/11/11:19:41:13    Spunky    SPUNKY-PC    Install    Edu update for Inventor 2014 - local resource update (DL21987424_LP_ENG)    Succeeded
2013/11/11:19:41:13    Spunky    SPUNKY-PC    Installing Eco Material Advisor:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:41:20    Spunky    SPUNKY-PC    Install    Eco Material Advisor    Succeeded
2013/11/11:19:41:20    Spunky    SPUNKY-PC    Installing Autodesk® Revit® Interoperability for Inventor 2014:  C_APP_NAME=Inventor C_APP_VER=2014 C_RES=ALL RX_PD="Inventor 2014" ADDLOCAL=RevitEngine,RPC,API,DWG INSTALLDIR="C:\Program Files\Autodesk\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},.NET Framework Runtime 3.5 SP1,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:43:20    Spunky    SPUNKY-PC    Install    Autodesk® Revit® Interoperability for Inventor 2014    Succeeded
2013/11/11:19:43:20    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2014\" DC_ANSI=1 DC_DIN=1 DC_GOST=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_OTHER=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor Content Libraries 2014"
2013/11/11:19:43:29    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® Content Libraries    Failed    Failure is ignored, Result=1603
2013/11/11:19:43:41    Spunky    SPUNKY-PC    Installing Autodesk® Vault Basic 2014 (Client):  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\x64\en-us\Vault\Vault.mst;C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\x64\Vault\Vault-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:45:42    Spunky    SPUNKY-PC    Install    Autodesk® Vault Basic 2014 (Client)    Succeeded
2013/11/11:19:45:42    Spunky    SPUNKY-PC    Installing Autodesk® Vault Basic 2014 Language Pack:  TRANSFORMS="C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\_la943F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:45:53    Spunky    SPUNKY-PC    Install    Autodesk® Vault Basic 2014 Language Pack    Succeeded
2013/11/11:19:45:53    Spunky    SPUNKY-PC    Installing Autodesk® ReCap:  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\x64\en-us\RC2014\AutodeskReCap.mst;C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\x64\RC2014\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:46:31    Spunky    SPUNKY-PC    Install    Autodesk® ReCap    Succeeded
2013/11/11:19:46:32    Spunky    SPUNKY-PC    Installing Autodesk® ReCap Language Pack:  TRANSFORMS="C:\Users\Spunky\AppData\Local\Temp\_AIC6FA.tmp\_la55BB.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/11:19:46:38    Spunky    SPUNKY-PC    Install    Autodesk® ReCap Language Pack    Succeeded
2013/11/11:19:46:40    Spunky    SPUNKY-PC    PageOpen    InstallCompleteDialog
2013/11/11:20:09:41    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:10:52    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:10:52    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:10:52    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:20:10:52    Spunky    SPUNKY-PC    Launch
2013/11/11:20:10:52    Spunky    SPUNKY-PC    CommandLine
2013/11/11:20:10:52    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI9C91.tmp
2013/11/11:20:11:12    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:10:56    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:10:56    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:10:56    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI9C91.tmp
2013/11/11:20:10:56    Spunky    SPUNKY-PC    Launch
2013/11/11:20:10:58    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AI9C91.tmp\Setup\InventorUI.dll
2013/11/11:20:10:58    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/11:20:11:05    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:20:11:05    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:20:11:06    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:20:11:16    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:20:12:56    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:20:12:56    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:20:13:48    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:20:13:48    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:20:13:50    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:20:13:50    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:20:14:22    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/11:20:14:22    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2014\" DC_ANSI=1 DC_DIN=1 DC_GOST=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_OTHER=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor Content Libraries 2014"
2013/11/11:20:14:24    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® Content Libraries    Failed    Failure is ignored, Result=1603
2013/11/11:20:14:24    Spunky    SPUNKY-PC    PageOpen    InstallCompleteDialog
2013/11/11:20:14:54    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:15:32    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:15:32    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:15:32    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:20:15:32    Spunky    SPUNKY-PC    Launch
2013/11/11:20:15:32    Spunky    SPUNKY-PC    CommandLine
2013/11/11:20:15:32    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIE341.tmp
2013/11/11:20:15:37    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:15:34    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:15:34    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:15:34    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIE341.tmp
2013/11/11:20:15:34    Spunky    SPUNKY-PC    Launch
2013/11/11:20:15:34    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AIE341.tmp\Setup\InventorUI.dll
2013/11/11:20:15:34    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/11:20:15:37    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:20:15:37    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:20:15:38    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:20:15:40    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/11:20:15:42    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:20:15:56    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:20:15:56    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:20:16:08    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/11:20:16:08    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2014\" DC_ANSI=1 DC_DIN=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor Content Libraries 2014"
2013/11/11:20:16:09    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® Content Libraries    Failed    Failure is ignored, Result=1603
2013/11/11:20:16:09    Spunky    SPUNKY-PC    PageOpen    InstallCompleteDialog
2013/11/11:20:17:09    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:17:43    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:17:43    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:17:43    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:20:17:43    Spunky    SPUNKY-PC    Launch
2013/11/11:20:17:43    Spunky    SPUNKY-PC    CommandLine
2013/11/11:20:17:43    Spunky    SPUNKY-PC    An instance of setup is already running. Only one instance of setup can run at a time.2013/11/11:20:17:46    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:17:41    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:17:41    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:17:41    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/11:20:17:41    Spunky    SPUNKY-PC    Launch
2013/11/11:20:17:41    Spunky    SPUNKY-PC    CommandLine
2013/11/11:20:17:41    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIDD58.tmp
2013/11/11:20:17:53    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/11:20:17:48    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/11:20:17:48    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/11:20:17:48    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AIDD58.tmp
2013/11/11:20:17:48    Spunky    SPUNKY-PC    Launch
2013/11/11:20:17:49    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AIDD58.tmp\Setup\InventorUI.dll
2013/11/11:20:17:49    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/11:20:17:52    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/11:20:17:52    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/11:20:17:53    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/11:20:17:56    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/11:20:18:06    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/11:20:18:06    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/11:20:18:12    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/11:20:18:12    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2014\" DC_ANSI=1 DC_DIN=1 DC_GOST=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_OTHER=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor Content Libraries 2014"
2013/11/11:20:18:14    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® Content Libraries    Failed    Failure is ignored, Result=1603
2013/11/11:20:18:14    Spunky    SPUNKY-PC    PageOpen    InstallCompleteDialog
2013/11/11:20:18:17    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/12:17:44:03    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/12:17:44:03    Spunky    SPUNKY-PC    Launch
2013/11/12:17:44:03    Spunky    SPUNKY-PC    CommandLine    /P {7F4DD591-1864-0001-0000-7107D70F3DB4} /M INVENTOR /LANG en-US
2013/11/12:17:44:06    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/12:17:44:04    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/12:17:44:04    Spunky    SPUNKY-PC    Launch
2013/11/12:17:44:06    Spunky    SPUNKY-PC    PageOpen    MaintenanceDialog
2013/11/12:17:44:21    Spunky    SPUNKY-PC    PageOpen    MaintVerifyReadyDialog
2013/11/12:17:44:22    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/12:17:44:23    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:17:51:57    Spunky    SPUNKY-PC    Reinstall/uninstall     Autodesk® Inventor® 2014 ({7F4DD591-1864-0001-1033-7107D70F3DB4})    Succeeded
2013/11/12:17:51:57    Spunky    SPUNKY-PC    Uninstall    Autodesk® Inventor® 2014    Succeeded
2013/11/12:17:51:57    Spunky    SPUNKY-PC    PageOpen    MaintCompleteDialog
2013/11/12:17:52:55    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/12:17:53:48    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/12:17:53:48    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/12:17:53:48    Spunky    SPUNKY-PC    Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm
2013/11/12:17:53:48    Spunky    SPUNKY-PC    Launch
2013/11/12:17:53:48    Spunky    SPUNKY-PC    CommandLine
2013/11/12:17:53:48    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp
2013/11/12:17:54:34    Spunky    SPUNKY-PC    === Setup ended ===
2013/11/12:17:54:10    Spunky    SPUNKY-PC    === Setup started on SPUNKY-PC by Spunky ===
2013/11/12:17:54:10    Spunky    SPUNKY-PC    Path_Length: 182
2013/11/12:17:54:10    Spunky    SPUNKY-PC    Current Directory C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp
2013/11/12:17:54:10    Spunky    SPUNKY-PC    Launch
2013/11/12:17:54:12    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\Setup\InventorUI.dll
2013/11/12:17:54:12    Spunky    SPUNKY-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/12:17:54:32    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/11/12:17:54:32    Spunky    SPUNKY-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/11/12:17:54:34    Spunky    SPUNKY-PC    PageOpen    LaunchDialog
2013/11/12:17:54:36    Spunky    SPUNKY-PC    PageOpen    LicenseDialog
2013/11/12:17:54:39    Spunky    SPUNKY-PC    PageOpen    ProductInfoDialog
2013/11/12:17:55:23    Spunky    SPUNKY-PC    PageOpen    InventorFlavorSelectionDialog
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==DefaultLanguage:    en-us
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==InstallName:    INVENTOR
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ProductName:    Autodesk Inventor 2014
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==DisplayName:    Autodesk® Inventor® 2014
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==DeploymentName:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SetupTitle:    Autodesk Inventor 2014
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ConfigTransform:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ExeParams:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ProductCode:    {7F4DD591-1864-0001-0000-7107D70F3DB4}
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SupportLink:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==InfotainmentLink:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==MsiFileName:    inventor.msi
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==AdminImageConfigName:    Imgx64
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==AdminImageRoot:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==GetBaseDeploymentName:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==DeploymentLocation:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==DocumentLink:    http://autodesk.com/wikihelp-inventor-install-2014-enu
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==InstallDeploymentShortcut:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ModifyDeploymentShortcut:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SetupLockType:    2
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SetupNetworkType:     1
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SystemLocale:    2057
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==EvalMsiFilePath:    C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\SetupRes\eval.msi
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==EulaPath:    C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\EULA
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==InstallLogPath:    C:\Users\Spunky\AppData\Local\Temp\Inventor2014Install.log
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==ConfigFile:    C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\Setup.ini
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SetupPath:    C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==NetworkLogPath:
2013/11/12:17:55:23    Spunky    SPUNKY-PC    Inventorui==SourceRoot:    C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\
2013/11/12:17:56:17    Spunky    SPUNKY-PC    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/11/12:17:56:17    Spunky    SPUNKY-PC    PageOpen    ProductSelectionDialog2
2013/11/12:17:56:32    Spunky    SPUNKY-PC    PageOpen    FullProgressDialog
2013/11/12:17:56:32    Spunky    SPUNKY-PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:17:57:00    Spunky    SPUNKY-PC    Install    Autodesk Material Library 2014    Succeeded
2013/11/12:17:57:00    Spunky    SPUNKY-PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:17:57:44    Spunky    SPUNKY-PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/11/12:17:57:44    Spunky    SPUNKY-PC    Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/12:17:58:38    Spunky    SPUNKY-PC    Install    DirectX® Runtime    Succeeded
2013/11/12:17:58:38    Spunky    SPUNKY-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:18:00:19    Spunky    SPUNKY-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2013/11/12:18:00:20    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014:  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\x64\en-us\Inventor\inventor.mst;C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:18:11:04    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® 2014    Succeeded
2013/11/12:18:11:05    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® 2014 Language Pack:  TRANSFORMS="C:\Users\Spunky\AppData\Local\Temp\_AI7F98.tmp\_la4C6C.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:18:13:47    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® 2014 Language Pack    Succeeded
2013/11/12:18:14:55    Spunky    SPUNKY-PC    Install    Edu update for Inventor 2014 (DL21987424)    Succeeded
2013/11/12:18:15:01    Spunky    SPUNKY-PC    Install    Edu update for Inventor 2014 - local resource update (DL21987424_LP_ENG)    Succeeded
2013/11/12:18:15:01    Spunky    SPUNKY-PC    Installing Autodesk® Revit® Interoperability for Inventor 2014:  C_APP_NAME=Inventor C_APP_VER=2014 C_RES=ALL RX_PD="Inventor 2014" ADDLOCAL=RevitEngine,RPC,API,DWG INSTALLDIR="C:\Program Files\Autodesk\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},.NET Framework Runtime 3.5 SP1,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/12:18:17:07    Spunky    SPUNKY-PC    Install    Autodesk® Revit® Interoperability for Inventor 2014    Succeeded
2013/11/12:18:17:07    Spunky    SPUNKY-PC    Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_dlm\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2014\" DC_ANSI=1 DC_DIN=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor Content Libraries 2014"
2013/11/12:18:17:19    Spunky    SPUNKY-PC    Install    Autodesk® Inventor® Content Libraries    Failed    Failure is ignored, Result=1603
many thanks,
jonathan
5 REPLIES 5
fixed by redownloading the install and re-installing
Hi folks, I needed to bump this topic because I'm having the same issue with the same details and the solution provided isn't working for me. I've done a number of re-installs and still the same error. I've re-downloaded the web download package again and still the same error. This is very frustrating. In addition to that primary error, I get a message regarding failure to load start menu uninstall link. If figure that's not too important so I'm willing to ignore that issue.
I think i had to re download the installation to get it to work correctly although im unsure how i managed it
hi, did you manage to get yours sorted, I am having the same issue, Autodesk Inventor Content Libraries is failing to install.
I didn't get to solve that problem. Luckily I got a new SSD for my computer and just did a clean install. I think that the registry was messed up by the fact I had tried uninstalling autodesk Inventor 2013 and Autocad 2013 prior to installing 2014. Unfortunately, I don't have any ideas to fix this issue. =(
Administrator Productivity
