Installation & Licensing
chadkendall
554 Views, 3 Replies
Inventor 2013 SP1.1
Tried to install and got an error "No valid sequence could be found for the set of patches".
Tried this with SP1 uninstalled and also tried it with SP1 installed.
Any one have any ideas?
Windows 7 64bit
Inventor Pro 2013
3 REPLIES 3
TravisNave
in reply to: chadkendall
What problem are you experiencing that the Service Pack addresses?
http://images.autodesk.com/adsk/files/inventor_2013_sp1-1_readme_v1.htm
Autodesk Forums:
chadkendall
in reply to: TravisNave
Mostly crashing. Inventor unexpectidly exits frequently.
TravisNave
You might actually check to make sure that you are using a recommended video card that meets system requirements and are using a WHQL certified driver.  9/10 times the crash is due to video related issues.  I doubt a service pack will resolve your issue.
Autodesk Forums:
Administrator Productivity
