Installation & Licensing
Inventor 2013 Deployment Failed
3 REPLIES 3
karthur1
337 Views, 3 Replies
Ran my deployment and I get this message:
Internal Error 2602
I have already tried modifying the deployment and I get the same error.  I am deleting/recreating teh deployment.  Not very happy with the deployment for 2013 so far.
3 REPLIES 3
TravisNave
in reply to: karthur1
Are you creating a deployment with any hotfixes?  And did you use a UNC path will full read/write access?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
karthur1
in reply to: TravisNave
Hotfixes... No, but I would like to.  It says its up-to-date, thus I can't add include any hotfix in the deployment.  Of course, there is an update1 for Inventor.
I'm getting the same error number, although the filename of the dll is different.
Originally received this error via a network deployment package. Then copied the entire directory to my local hard drive and recreated the deployment package, still errors out. Then found the 3D Studio Max msi and ran just that and it still errors out.
Version 2012
Win 7 Pro
AJ
Administrator Productivity
