Installation & Licensing
Inventor 2012 Install problems
3 REPLIES 3
Moff14
1319 Views, 3 Replies
Having problems gettting Inventor 2012 to install.
First attempt failed on Design Review, now failed twice on Sketchbook Designer.
Error message is:       1: 5 2: adlmPITSetProductInformation failed. 3: 2
Windows 7 64-bit
Intel Core i7
Log attached.
3 REPLIES 3
emily.xu
in reply to: Moff14
Maybe a corruption in the ProductInformation.pit file.  The workaround is to manually remove this file and then run the installation process again.
The ProductInformation.pit file can be found on the workstation in the following locations:
Windows XP:
C:\Documents and settings\All Users\Application Data\Autodesk\ADLM\ProductInformation.pit
Windows Vista:
C:\ProgramData\Autodesk\ADLM\ProductInformation.pit
Emily Xu
Product Support
Moff14
in reply to: emily.xu
Ok, removed the file as requested and the installation has progressed a bit further, but not too far.
An error is not flashing up about needing to shut down Windows Explorer.
Any action after this kills the install.
emily.xu
in reply to: Moff14
I would suggest you remove all the Autodesk Products first, especially delete related folders and registers by this solution: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697.
Then use your administrator user to login your machine, close all the others applications, including anti-virus and firewall,close UAC and try to reinstall from a clean system.
Hope helps.
Emily Xu
Product Support
Administrator Productivity
