Having a couple problems with my ADA2012 install.
Currently only working on my Teacher PC and 1 Student
PC for my Project Lead the Way PC Lab. PC 's are brand new. Both are Core i5, Win7 Pro x64. Logged on as an administrator to both.
Built Revit and Inventor Install Packages no problem.
Installed License Server on Teacher PC. Registered and
got license file from Autodesk. License being read and used, server running.
All looks good.
When I try to install Inventor on either PC, it fails. The log file is attached.
Try installing from media instead of a deployment and see if you get the same error.
The install completes when installing from mmedia, but this is going to seriously slow down the completion of this lab, as I have 24 more PC's to load. Thanks for the tip.
