Installation & Licensing
Inventor 2012 Content Centre
1 REPLY 1
moosabismillah
705 Views, 1 Reply
I have downloaded the installations files for Inventor 2012 from the Autodesk Website.
I normally create a deployment image to install AutoCAD and Inventor onto several machines.
For Inventor 2010 we had to deploy the image and then install the content centre separately using the disks as we have them stored locally on each machine.
I have been reading the help files, for Inventor 2012 installations, and it says "To add a default library after installation, run setup.exe from the Installation media and select the check box next to the libraries you want to install".
My question is can I install the content centre from the setup files I have downloaded from the website, or must I have the installation files on Media.
Thanks.
1 REPLY 1
TravisNave
in reply to: moosabismillah
If you have downloaded the content center libraries, you can use that to install in lieu of the physical media.
Autodesk Forums:
Administrator Productivity
