I began using the student version of Inventor 2011 last month and encountered a s/w problem that closed the program yesterday. When I reported it, I was directed to download a patch (inventor_2011_sp1_x640).
I loaded it and have since rebooted but when I try to run Inventor I now get an error saying that "Inventor.exe is not currently registered and did not correctly re-register on start up. This is probably because you do not have enough access rights (e.g. you are a Restricted User). Ask an Administrator of Standard User to re-run the program for you."
I have the original student serial number and activation code but I don't know where or how to reload them.
PLEASE help me. The AutoDesk Student Community website has been undergoing maintenance and I don't know where to turn for help. I have a class project due tomorrow and I have to finish working on my files.
Thank you.
It is refering to the product executable registered to Windows. You probably just need to do a repair install and you'll be fine. Your license is unaffected.
Please tell me how this can be accomplished.... or should I just uninstall and reinstall all of AutoDesk? Thank you.
You can try a repair from Control Panel. Worst case, reinstall as you mentioned.
