Hi all,
I have a question about Inventor 2010 professional student version 64 bit. I have downloaded the files for this program (I really need it for my school). But when I want to install, there is a problem. It says the CRC file is damaged, so the wizard can't finish. This problem occured with extracting the files. Setup doesn't work because some files are missing because of the damaged files.
What can I do to make it work? Or can you give me a student version (2009 or 2010) which works?
Greetings
Hi tomvandeven19991,
Corrupt and/or missing installation files are often the result of having your system behind a firewall or anti-virus program while downloading your software. Please, make sure your firewall and anti-virus programs are not blocking content from *.autodesk.com and try the download again (or simply disable your firewall and anti-virus programs - at your own risk).
Let us know if this works.
Too bad, that didnt work:( still keeps saying CRC file damaged, even if i download without firewall or anti-virus.
Do you have some more tips for me?
CRC errors may also be avoided by using a different web browser, or an alternate download method.
