Installation & Licensing
Inventor 2010 and Vault 2011
4 REPLIES 4
828 Views, 4 Replies
I've looked through the FAQs and deployment white papers but I am still not clear about what strategy I should take to migrate our machines to Inventor 2011.
We are currently running Inventor and Vault 2010 on 32-bit XP machines, and are current in the process of upgrading them to Inventor/Vault 2011 on 64-bit Windows 7 machines.
The problem is that some of the users are not ready to upgrade so fast so we would like to do it little bit at a time. So my question is "can Inventor/Vault Client 2010 work with Vault Server 2011?"
I'm pretty sure this is not doable, but even if it was, I imagine other problems will occur once files from Inventor 2011 and 2010 get mixed up together in the same Vault.
4 REPLIES 4
Antonio_Barroca
Before upgrading to Vault 2011 please wait the release of the “Inventor 2010 Compatibility Patch for ADMS 2011” to be able to connect to Vault 2011 (ADMS 2011).
This patch will be released soon, but the exact date is not yet fixed.
For mixing files between 2010 and 2011 there is no problem, but please note, if you save the files in version 2011 you will not be able open them in 2010 anymore.
Regards
Antonio Barroca
Autodesk Product Support
We appreciate your quick feedback on this forum!
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
Thank you for the reply and I will wait eagerly for the release of the compatibility patch.
Can't wait to deploy the new versions into production!
suppfalt
Is there a release date for the "Inventor 2010 Compatibility Patch for ADMS 2011"?
it should be released with Inventor 2010 SP3. you can get the SP available
information via the Communicate Center in Inventor.
After you get it, please first install Inventor 2010 SP1, SP2 and SP3, then
install the "Inventor 2010 Compatibility Patch for ADMS 2011"
Administrator Productivity
