Installation & Licensing
invalid serial number autocad 2009
4 REPLIES 4
2967 Views, 4 Replies
Hi
If someone can help me please, I need help for an activation for autcad 2009 LT, i write the serial number i have on the autocad box and I received an invalid serial number? How can i active it.
The cd key is : N/A?
Yves
4 REPLIES 4
TravisNave
Welcome to the community.
The 2009 product has been retired under Subscription.  Therefore, if you ever upgraded, crossgraded, or had the product under Subscription at any point, then you are likely unable to install and activate this software.  If it was upgraded or fulfilled to a later version under Subscription, you should still be able to install and activate your most recent version.
Otherwise, see my invalid serial number link below.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=22021115&linkID=9240617&siteID=123112
Your product key is most likely 057A1.
If you need further assistance, you might contact your VAR or philip.s here in the community.
Good Luck.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Ok thank you fo your help
Good day!
Yves
pximenez
I´ve installed an update for 2009 and now I can´t activate my Acad 2009 LT any more, what to do??
I need to use my Acad 2009...
Hello pximenez,
Welcome to the community!
To get help activating your AutoCAD 2009, please contact the Activation and Registration team directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
If you have any other questions or concerns please reply to this post. Thank you!
Simona Golisciano
Administrator Productivity
