Installation & Licensing
Member
CannebergesAtoka
Message 1 of 5 (1,331 Views)
invalid serial number autocad 2009
1331 Views, 4 Replies
08-12-2013 08:43 AM
Hi
If someone can help me please, I need help for an activation for autcad 2009 LT, i write the serial number i have on the autocad box and I received an invalid serial number? How can i active it.
The cd key is : N/A?
Yves
TravisNave
Message 2 of 5 (1,320 Views)
Re: invalid serial number autocad 2009
08-12-2013 09:39 AM in reply to: CannebergesAtoka
Welcome to the community.
The 2009 product has been retired under Subscription.  Therefore, if you ever upgraded, crossgraded, or had the product under Subscription at any point, then you are likely unable to install and activate this software.  If it was upgraded or fulfilled to a later version under Subscription, you should still be able to install and activate your most recent version.
Otherwise, see my invalid serial number link below.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=22021115&linkID=9240617&siteID=123112
Your product key is most likely 057A1.
If you need further assistance, you might contact your VAR or philip.s here in the community.
Good Luck.
Member
CannebergesAtoka
Message 3 of 5 (1,306 Views)
08-12-2013 12:00 PM in reply to: TravisNave
Ok thank you fo your help
Good day!
Yves
New Member
pximenez
Message 4 of 5 (80 Views)
11-11-2014 01:14 AM in reply to: TravisNave
I´ve installed an update for 2009 and now I can´t activate my Acad 2009 LT any more, what to do??
I need to use my Acad 2009...
Customer Service
simona.golisciano
Message 5 of 5 (71 Views)
11-11-2014 02:30 AM in reply to: pximenez
Hello pximenez,
Welcome to the community!
To get help activating your AutoCAD 2009, please contact the Activation and Registration team directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
If you have any other questions or concerns please reply to this post. Thank you!
Simona Golisciano
