Installation & Licensing
sbryan
147 Views, 2 Replies
Interesting problems
We have a single license server which hands out 18 AutoCAD 2006 licenses and 2 ABS 2006 Licenses.
What's interesting is that ABS on one computer takes out an AutoCAD license. On another computer, ABS takes out the correct license.
I'm sure I created a different deployment for these two, and as I recall, there's no license customization in that Deployment Wizard -- just the path to the license file which holds the information for our Autodesk products.
Has anybody seen this problem before? It's important that we have those 18 AutoCAD licenses -- 17 would mean one user browses the internet for the work day!
Thanks.
2 REPLIES 2
TravisNave
in reply to: sbryan
I could see why if this were 2007 and the rollover licensing were in affect. But that wasn't an option in 2006. I find it hard to believe that ABS would pull an AutoCAD license since the program uses the feature code to get a license from the NLM.
Might check your debug log files in LMTOOLS.
Autodesk Forums:
sbryan
in reply to: sbryan
Now that you mention it, we have one license that can be used as an AutoCAD 2006 or 2007 license.
(AutoCAD 2007 is in the testing phase...)
Administrator Productivity
