I am attempting to install AutoCAD 2011LT on my Windows 7 Professional computer. After performing the configuration I get an Error 1303. user has insufficient privileges to access C:\User\Dennis\AppData\Local\Autodesk\AutoCADD LT 2001\R8. i am logged in with administative privileges (my user is an administrator). I have also tried running the install using "Run As Administrator". I get the same results either way.I got the same error earlier whan I tried to install TrueView 2011. What is going on??
UAC was already turned off. I disabled virus checking although I seriously doubt it has anything to do with this problem. It apparently did not because I get the same error. However, this time instead of having he last folder in the string names "R8" the last folder was "R16". Incidentally, if I open the AutoCAD LT 2011 folder that is the parent to the offending location, I can do anything I want to. I can add folders and files and delete them at will. So Windows allows me to do anything I want in that location. It is just that the installer for some reason does not think it has access.
