I cannot acces the following file: http://localhost/TestASP/TestASPNetStatic.txt.
When I try to acces http://localhost no problem when I try to acces http://localhost/TestASP I get 'Cannot acces webpage'.
When I open TestASP on the IIS below the Default website no problem.
How can I fix this problem.
Jan Martijn
Try disabling you firewall.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
If you disable the firewall and you're still getting the error. Uninstall .NET Framework 4.5 and have the Vault installation install it for you.
Darin Green
Thanks for the replieds. But still the problem is active.
I uninstal the framework and let the Vault install the framework.
But stil I get the error.
Thanks for the help.
Jan Martijn Lenselink
Holland Systemen
