Is there a way to install Revit Student in a drive that is not C?
My C: drive is quite small, so I tend to install most of my programs on my E: drive (I have my reasons). The Revit installer allows you to change the install directory but seems to ignore it. If I click Install it gives an error stating that my C: drive is full even after I've changed it to install on E.
Is there any solution to this or will I have to go through my C drive trying to find things to clear out?
Thank you.
By default all the Templates and Libraries for Revit are still trying to install to C:\ProgramData.
On the product selection dialog of the install, just under the Revit 2013 name pick the arrow to configure the install.
Scroll down to the Configurable Folders section
Change the Libraries and Templates from Default to Local
Specify a path on the B driver where you want these files and choose the Append button
When done choose the arrow again to complete the configuration
Should use much less space on the C drive now although some space will still be required.
Danny
