Installation & Licensing
Installing Revit Error
40 REPLIES 40
Message 1 of 41
5dunhams
12599 Views, 40 Replies
While installing Revit 2014 Student Version I get the error the media does not contain content and will be downlaoded during instalation while configuring the installation. It "installs" but says some products failed to install. Both Revit and the Materials Library failed to install. Any idea how to fix?
40 REPLIES 40
Message 21 of 41
TravisNave
Go into your Contol Panel > Programs and Features.
Remove this:
Microsoft Visual C++ 2005 Redistributable (x86)
Reinstall Autodesk product.
Autodesk Forums:
Message 22 of 41
paul.alcos
Just do the browser installation, that works for me. It will take a while
though. Good luck!
Message 23 of 41
in reply to: paul.alcos
how?
Message 24 of 41
TravisNave
I told you how. If you need pictures then click my 1603 link. That should
help if needed. 🙂
Autodesk Forums:
Message 25 of 41
in reply to: TravisNave
done, still the same error.please help
Message 26 of 41
PERogers1
in reply to: 5dunhams
We have exactly the same problem on a brand new HP ENVY machine.  Could the problem be the need to disable McAfee?
Message 27 of 41
JoepvanMotman
can you please be more specific. Go to Program files(x86)? ....
Message 28 of 41
When i install Revit during the instalation i see the Revit logo on my desktop. I can open it and start using the programm. But when the ''installation'' is complete it wil delete the logo from my desktop and all other place on my computer. Why is this happening, i need the program for my school very soon so i hope someone can help me!?
Message 29 of 41
TravisNave
It's failing and then rolling back due to a download issue.
Install	Autodesk Material Library 2014 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
The virtual assistant isn't working correctly at the moment, so I don't really know what else to tell you.
Autodesk Forums:
Message 30 of 41
is there any easy fix for this. It's driving me mad, surely there shouldn't be these problems. This is a joke, surely a company the size of autodesk can fix this problem.
I get this message "the media does not contain content and will be downloaded during installation" when i try to install.
I shouldn't have to delve into windows files and change things for this to work. I would definitely consider other programs in the future because this is not acceptable
Message 31 of 41
Ariel_34
Hi, please help me install Revit (student version) on my PC (Windows 😎
instalation log down below
2014/3/15:18:28:57 Ariel_2 ARIEL === Setup started on ARIEL by Ariel_2 ===
2014/3/15:18:28:57 Ariel_2 ARIEL Path_Length: 149
2014/3/15:18:28:57 Ariel_2 ARIEL Current Directory C:\Users\Ariel_2\AppData\Local\Temp\_AI4FB7.tmp
2014/3/15:18:28:57 Ariel_2 ARIEL Launch
2014/3/15:18:28:59 Ariel_2 ARIEL Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/3/15:18:28:59 Ariel_2 ARIEL Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Ariel_2\AppData\Local\Temp\_AI4FB7.tmp\Setup\RevitSetup.dll
2014/3/15:18:28:59 Ariel_2 ARIEL Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/15:18:29:02 Ariel_2 ARIEL PageOpen LaunchDialog
2014/3/15:18:33:31 Ariel_2 ARIEL PageOpen LicenseDialog
2014/3/15:18:35:46 Ariel_2 ARIEL PageOpen ProductInfoDialog
2014/3/15:18:35:47 Ariel_2 ARIEL PageOpen ProductSelectionDialog2
2014/3/15:18:36:04 Ariel_2 ARIEL PageOpen FullProgressDialog
2014/3/15:18:36:05 Ariel_2 ARIEL Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/3/15:18:36:05 Ariel_2 ARIEL Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ariel_2\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/3/15:18:36:37 Ariel_2 ARIEL Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/3/15:18:36:37 Ariel_2 ARIEL Download Skipped VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/3/15:18:36:37 Ariel_2 ARIEL Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ariel_2\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/3/15:18:36:54 Ariel_2 ARIEL Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/3/15:18:36:55 Ariel_2 ARIEL Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:36:55 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:36:59 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/3/15:18:37:00 Ariel_2 ARIEL Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:00 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:37:16 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/3/15:18:37:16 Ariel_2 ARIEL Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:16 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:37:27 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/3/15:18:37:27 Ariel_2 ARIEL Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:27 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:37:35 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/3/15:18:37:35 Ariel_2 ARIEL Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:35 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:37:40 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/3/15:18:37:40 Ariel_2 ARIEL Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:40 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:37:52 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/3/15:18:37:52 Ariel_2 ARIEL Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:37:52 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:38:01 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/3/15:18:38:02 Ariel_2 ARIEL Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/3/15:18:38:02 Ariel_2 ARIEL Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/15:18:38:09 Ariel_2 ARIEL Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/3/15:18:38:10 Ariel_2 ARIEL Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/3/15:18:38:10 Ariel_2 ARIEL Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ariel_2\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/3/15:18:38:59 Ariel_2 ARIEL Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/3/15:18:38:59 Ariel_2 ARIEL Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/3/15:18:38:59 Ariel_2 ARIEL Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ariel_2\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/3/15:18:39:30 Ariel_2 ARIEL Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/3/15:18:39:31 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/3/15:18:39:37 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/3/15:18:39:43 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/3/15:18:39:50 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/3/15:18:39:54 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/3/15:18:40:01 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/3/15:18:40:07 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/3/15:18:40:14 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/3/15:18:40:18 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/3/15:18:40:18 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/3/15:18:40:19 Ariel_2 ARIEL Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Message 32 of 41
jdbasalo
where can find installation log? i'm not really good at computer.
Message 33 of 41
Hey Travis,
I have the same problem as it downloads/installs whole thing then at end states some products failed to install which then they have all failed to install.This happens for all verions '14, '15 etc. I have tried several times to install. Also tried formating my desktop.
Tags (1)
Message 34 of 41
TravisNave
Jeremy,
It is failing on the download.
Install	Autodesk Material Library 2015 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
Autodesk Forums:
Message 35 of 41
Jazzi00
in reply to: Tony_Michniewicz
I am having issues with re-downloading revit 2014.. getting error 997...
2014/11/1:21:03:31 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:03:31 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:03:31 Jazzi JAZZI-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/11/1:21:03:31 Jazzi JAZZI-HP Launch
2014/11/1:21:03:31 Jazzi JAZZI-HP CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /skipPI /SN 900-44139555 /PK 829F1 /akamai
2014/11/1:21:03:31 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AI29DE.tmp
2014/11/1:21:03:32 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:03:32 Jazzi JAZZI-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2014/11/1:21:03:32 Jazzi JAZZI-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jazzi\AppData\Local\Temp\_AI29DE.tmp\Setup\RevitSetup.dll
2014/11/1:21:03:32 Jazzi JAZZI-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/1:21:03:32 Jazzi JAZZI-HP PageOpen LaunchDialog
2014/11/1:21:05:18 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:05:22 Jazzi JAZZI-HP PageOpen ProductInfoDialog
2014/11/1:21:05:22 Jazzi JAZZI-HP PageOpen ProductSelectionDialog2
2014/11/1:21:05:32 Jazzi JAZZI-HP PageOpen FullProgressDialog
2014/11/1:21:05:32 Jazzi JAZZI-HP Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.ta...
2014/11/1:21:05:32 Jazzi JAZZI-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/1:21:05:32 Jazzi JAZZI-HP Install DirectX® Runtime Failed Failure is ignored, Result=2
2014/11/1:21:05:32 Jazzi JAZZI-HP Download Skipped RVT2014 http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x6...
2014/11/1:21:05:32 Jazzi JAZZI-HP Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Jazzi\AppData\Local\Temp\_AI29DE.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/1:21:05:38 Jazzi JAZZI-HP Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/11/1:21:05:38 Jazzi JAZZI-HP PageOpen InstallCompleteDialog
2014/11/1:21:14:58 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:15:05 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:15:05 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:15:05 Jazzi JAZZI-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/11/1:21:15:05 Jazzi JAZZI-HP Launch
2014/11/1:21:15:05 Jazzi JAZZI-HP CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /skipPI /SN 900-44139555 /PK 829F1 /akamai
2014/11/1:21:15:05 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AIC2F2.tmp
2014/11/1:21:15:07 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:15:06 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:15:06 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:15:06 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AIC2F2.tmp
2014/11/1:21:15:06 Jazzi JAZZI-HP Launch
2014/11/1:21:15:06 Jazzi JAZZI-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2014/11/1:21:15:06 Jazzi JAZZI-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jazzi\AppData\Local\Temp\_AIC2F2.tmp\Setup\RevitSetup.dll
2014/11/1:21:15:06 Jazzi JAZZI-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/1:21:15:06 Jazzi JAZZI-HP PageOpen LaunchDialog
2014/11/1:21:16:24 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:17:13 Jazzi JAZZI-HP PageOpen ProductInfoDialog
2014/11/1:21:17:13 Jazzi JAZZI-HP PageOpen ProductSelectionDialog2
2014/11/1:21:17:19 Jazzi JAZZI-HP PageOpen FullProgressDialog
2014/11/1:21:17:19 Jazzi JAZZI-HP Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.ta...
2014/11/1:21:17:19 Jazzi JAZZI-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/1:21:17:19 Jazzi JAZZI-HP Install DirectX® Runtime Failed Failure is ignored, Result=2
2014/11/1:21:17:19 Jazzi JAZZI-HP Download Skipped RVT2014 http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x6...
2014/11/1:21:17:19 Jazzi JAZZI-HP Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Jazzi\AppData\Local\Temp\_AIC2F2.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/1:21:17:53 Jazzi JAZZI-HP Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/11/1:21:17:53 Jazzi JAZZI-HP PageOpen InstallCompleteDialog
2014/11/1:21:18:18 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:31:01 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:31:01 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:31:01 Jazzi JAZZI-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/11/1:21:31:01 Jazzi JAZZI-HP Launch
2014/11/1:21:31:01 Jazzi JAZZI-HP CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /skipPI /SN 900-44139555 /PK 829F1 /akamai
2014/11/1:21:31:01 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AI5938.tmp
2014/11/1:21:31:03 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:31:02 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:31:02 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:31:02 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AI5938.tmp
2014/11/1:21:31:02 Jazzi JAZZI-HP Launch
2014/11/1:21:31:02 Jazzi JAZZI-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2014/11/1:21:31:02 Jazzi JAZZI-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jazzi\AppData\Local\Temp\_AI5938.tmp\Setup\RevitSetup.dll
2014/11/1:21:31:02 Jazzi JAZZI-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/1:21:31:02 Jazzi JAZZI-HP PageOpen LaunchDialog
2014/11/1:21:34:15 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:34:20 Jazzi JAZZI-HP PageOpen ProductSelectionDialog2
2014/11/1:21:53:17 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:53:19 Jazzi JAZZI-HP PageOpen ProductSelectionDialog2
2014/11/1:21:53:23 Jazzi JAZZI-HP PageOpen FullProgressDialog
2014/11/1:21:53:24 Jazzi JAZZI-HP Download Skipped CADM http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CADM_x64_e...
2014/11/1:21:53:24 Jazzi JAZZI-HP Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/1:21:53:28 Jazzi JAZZI-HP Install Autodesk CAD Manager Tools Failed Failure is ignored, Result=1603
2014/11/1:21:53:28 Jazzi JAZZI-HP Download Skipped SDK http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SDK.tar.lz...
2014/11/1:21:53:28 Jazzi JAZZI-HP Installing Revit Software Development Kit: "C:\Autodesk\WI\Autodesk Revit 2014\Utilities\SDK\RevitSDK.exe" -d"C:\Revit SDK 2014"
2014/11/1:21:53:42 Jazzi JAZZI-HP Install Revit Software Development Kit Failed Failure is ignored, Result=255
2014/11/1:21:53:44 Jazzi JAZZI-HP PageOpen InstallCompleteDialog
2014/11/1:21:53:54 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:54:28 Jazzi JAZZI-HP === Setup started on JAZZI-HP by Jazzi ===
2014/11/1:21:54:28 Jazzi JAZZI-HP Path_Length: 149
2014/11/1:21:54:28 Jazzi JAZZI-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/11/1:21:54:28 Jazzi JAZZI-HP Launch
2014/11/1:21:54:28 Jazzi JAZZI-HP CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /skipPI /SN 900-44139555 /PK 829F1 /akamai
2014/11/1:21:54:28 Jazzi JAZZI-HP Current Directory C:\Users\Jazzi\AppData\Local\Temp\_AID01C.tmp
2014/11/1:21:54:30 Jazzi JAZZI-HP === Setup ended ===
2014/11/1:21:54:29 Jazzi JAZZI-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2014/11/1:21:54:29 Jazzi JAZZI-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jazzi\AppData\Local\Temp\_AID01C.tmp\Setup\RevitSetup.dll
2014/11/1:21:54:29 Jazzi JAZZI-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/1:21:54:29 Jazzi JAZZI-HP PageOpen LaunchDialog
2014/11/1:21:54:32 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:54:33 Jazzi JAZZI-HP PageOpen LaunchDialog
2014/11/1:21:55:36 Jazzi JAZZI-HP PageOpen LicenseDialog
2014/11/1:21:55:40 Jazzi JAZZI-HP PageOpen ProductInfoDialog
2014/11/1:21:55:40 Jazzi JAZZI-HP PageOpen ProductSelectionDialog2
2014/11/1:22:02:00 Jazzi JAZZI-HP PageOpen FullProgressDialog
2014/11/1:22:02:00 Jazzi JAZZI-HP Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.ta...
2014/11/1:22:02:00 Jazzi JAZZI-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/1:22:02:00 Jazzi JAZZI-HP Install DirectX® Runtime Failed Failure is ignored, Result=2
2014/11/1:22:02:00 Jazzi JAZZI-HP Download Skipped RVT2014 http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x6...
2014/11/1:22:02:01 Jazzi JAZZI-HP Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Jazzi\AppData\Local\Temp\_AID01C.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/1:22:02:11 Jazzi JAZZI-HP Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
can someone please help me I have mid terms this week and I've been fighting with this all quarter.
Message 36 of 41
Jazzi00
Please help me dowmload revit 2014  (i have tried everthing in the support center... from deleting the temp folder, manually uninstalling under the autodesk folder, down to deleting the registry key) I even tried the microsoft fix it... I am not too computer savy... I am completely lost PLEASE HELP!!! 😞  log below...
Message 37 of 41
JosuéEB27
in reply to: Jazzi00
i cant installing revit .. u.u
failure installation ..
help me plz ..
Message 38 of 41
jessica.t
in reply to: JosuéEB27
Hi @Jazzi00 and @josueEB27,
Please try re-downloading your software using the following precautions:
  • In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
  • In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
  • Turn off your personal firewall or VPN, if you use one.
  • Disable UAC
  • Close and reopen your preferred browser.
  • Re-download from the Virtual Agent
If the problem persists please let me know. Thanks!
Jessica Thrasher
Message 39 of 41
quyen-nguyen
in reply to: jessica.t
I have the same problem and also try all these but doesnt work. does anyone figure out a way? thanks
Message 40 of 41
quyen-nguyen
in reply to: quyen-nguyen
please help!!
[SETUP]
SETUP_CODE={7346B4A0-1400-0500-0000-705C0D862004}
SETUP_ICON=SetupRes\Revit.ico
TITLE=\Autodesk Revit 2014
LOG=%tmp%\Autodesk Revit 2014 Setup.log
EVALMSI=SetupRes\eval.msi
PRIMARY_MSI=x86\RVT2014\RVT2014.msi
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_ADD_LP
DEFAULTMEDIALANGUAGE=en-US
DOCUMENT_LINK=Documentation\help-relay-page-online-revit.html
DOCUMENT_FALLBACK_LINK=Documentation\help-relay-page-offline-revit.html
SUPPORT_LINK=Documentation\readme-redirect-RVT.htm
SUPPORT_FALLBACK_LINK=Documentation\Readme\RVT Readme.htm
SYSTEMREQUIRE_LINK=Documentation\sysreq-redirect-revit.htm
SYSTEMREQUIRE_FALLBACK_LINK=Documentation\SysReq\autodesk_revit_product_line_system_requirements_and_recommendations_final.pdf
EULA_LINK=http://www.autodesk.com
INSTALL_PATH=%ProgramFiles%\Autodesk
CREATE_DESKTOP_SHORTCUT=YES
SETUP_HIGHLIGHT_COLOR=#9955AA
#==================== Platform Requirement
OSMAJVER=6
OSMINVER=0
SPMAJVER=0
#==================== Graphics Card Check
#OGS_XML_FILE=Setup\OgsTest.xml
#==================== Install Execute & UI Sequence
EXE_SEQUENCE=RVT2014;CMILM2014;NLM;CADM;REVITSERVER;SDK;ADDONS
INSTALL_SEQUENCE=NLM;CADM;REVITSERVER;RVT2014;CMILM2014;SDK;ADDONS
UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;RVT2014;CMILM2014;NLM;CADM;REVITSERVER;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg;ADDONS
#==================== UI
UI_MODE=
#==================== Deployment Info
DEPLOYMENT_NAME=
CLIENT_LOGGING=YES
EXTRA_FILES=REVIT;*.exe:eula:nlsdl:Setup:SetupRes:%lang%:3rdParty\MSI:Content
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=Setup\RevitConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2014.0.0.F
ADLM_TRIAL_DAYS=30
#==================== Custom Callback
CB_SOURCE=Setup\RevitSetup.dll
CB_PARAM=7.0.5730;7.0
CB_DESCRIPTION=Detecting Revit Supported Platforms
#==================== Global MSI Properties
PATH_LENGTH=149
[GLOBAL_MSI_PROPERTIES]
[MSI]
#== This is duplicated from [MSI4]
#== This is only needed if you list MSI in SYSUPDATE
PLATFORM=ALL
PRODUCT_NAME=Windows Installer Redistributable
EXE_PATH=3rdParty\MSI
EXE_PARAM=/quiet /norestart
VC_FUNC=MsiVerCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI
#==================== REVIT
[RVT2014]
PRODUCT_NAME=Autodesk® Revit® 2014
EXE_PATH=x86\RVT2014\RVT2014.msi
EXE64_PATH=x64\RVT2014\RVT2014.msi
LOG=%tmp%\Autodesk Revit 2014 Install.log
PRODUCT_MESSAGE=RevitSetupRes.dll;303
PLATFORM=NATIVE
ADMIN_INSTALL=NO
PREREQUISITE=RevitOSVersionCheck;IE7;SSE2;VCREDIST2008SP1X64;VCREDIST2008SP1X64_6161;VCREDIST2005X86;VCREDIST2005X64;VCREDIST2008SP1X86;VCREDIST2008SP1X86_6161;VCREDIST2010SP1X86;VCREDIST2010SP1X64;KB958314ATLX86;KB958314MFCX86;KB958314CRTX86;KB958314OPENMPX86;KB958314ATLX64;KB958314MFCX64;KB958314CRTX64;KB958314OPENMPX64;VCREDIST2005SP1ATLX86;VCREDIST2005SP1ATLX64;_DOTNET35SP1;DOTNET45;DOTNET45LANG;DIRECTX;FaroSDK;
#LS PREREQUISITE=
POSTREQUISITE=WORKFLOWS;CM2014;CMILB2014;CMILL2014
EXE_PARAM=
ACTION=INSTALL
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
UI_SEQUENCE=RevitShortcutPanel;RevitSettingsPage;DisciplinePage;UKResPage;RevitContentPackPanel;RevitConfigFolderPanel;AddAdditionalFilesPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage;RevitServerAddressPanel
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;RevitContentPackDialog;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
DISKCOST_FUNC=BSDGetDiskCost
DISKCOST_SOURCE=Setup\RevitContentPackUI.dll
INSTALL_FINALIZE=ContentPackFinalize
INSTALL_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
ALLOW_ADD_REMOVE=YES
EULA_PATH=eula
AVAILABLELANGUAGES=en-US
LPMODE=MUI
MUILPLINK=http://www.autodesk.com/revit-languagepacks
MSINEWINSTANCE=1
DEPLOYMENTLANGUAGE=en-US
DISK_PROMPT=RevitSetupRes.dll;107
DISK_LABEL=RVT2014
[RVT2014_LANGPACK]
PRODUCT_NAME=Autodesk® Revit® 2014 Language Pack
EXE_PATH=x86\%lang%\RVT2014\RVT2014LP.msi
EXE64_PATH=x64\%lang%\RVT2014\RVT2014LP.msi
ADMIN_INSTALL=NO
LOG=%tmp%\Autodesk Revit 2014 LangPack Install.log
[RVT2014_en-US]
DISK_LABEL=RVT2014
[RevitShortcutPanel]
UI_CREATOR=RevitShortcutPanel
UI_SOURCE=Setup\RevitSetup.dll
[RevitOSVersionCheck]
VC_FUNC=RevitOSVersionCheck
VC_SOURCE=Setup\RevitSetup.dll
VC_PARAM=7.0.5730;7.0
VC_DESCRIPTION=Detecting Revit Supported Platforms
#==================== REVIT Server
[REVITSERVER]
PLATFORM=x64
PRODUCT_NAME=Revit Server
PRODUCT_MESSAGE=RevitSetupRes.dll;503
PREREQUISITE=RevitServerOsVerCheck;DOTNET45;DOTNET45LANG
PRODUCT_GROUP=
EULA_PATH=eula
LOG=%tmp%\Autodesk Revit Server 2014 Install.log
EXE_PATH=%platform%\Tools\RS2014\RevitServer.msi
UI_SEQUENCE=RevitServerRolesPanel;RevitServerUsersPanel
INSTALL_TYPE=4
IGNORE_FAILURE=NO
[RevitServerAddressPanel]
UI_CREATOR=RevitServerAddressPanel
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[RevitServerRolesPanel]
UI_CREATOR=RevitServerRolesPanel
[RevitServerUsersPanel]
UI_CREATOR=RevitServerUsersPanel
[RevitServerOsVerCheck]
VC_FUNC=RevitServerOsVerCheck
VC_DESCRIPTION=Detecting Windows Server 2008
#==================== Modified Main Pages: Install Mode
[ADDONS]
INSTALL_TYPE=2
PRODUCT_NAME=\setupres.dll;189
PRODUCT_MESSAGE=SetupRes.dll;187
ACTION=INSTALL
UI_SEQUENCE=AddAddonPage
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
UI_CONSTRUCT_SOURCE=Setup\RevitContentPackUI.dll
UI_CONSTRUCT=cp_LaunchDlgConstruct
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
UI_CONSTRUCT=SelectionDlgConstruct
UI_FINALIZE=RevitCreateCustomIni
UI_FINALIZE_SOURCE=Setup\RevitSetup.dll
#== The background image could change for you
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" AND NOT ADSK_OEMPREINSTALL
UI_FINALIZE=ContentNetCheck
UI_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
UI_CONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_CONSTRUCT=RevitDownloadContent
#================ Needed by REVIT =======================================================
[SDK]
PLATFORM=ALL
PRODUCT_NAME=Revit Software Development Kit
PRODUCT_GROUP=Supplemental Tools
EXE_PATH=Utilities\SDK\RevitSDK.exe
EXE_PARAM=-d"%SystemDrive%\Revit SDK 2014"
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
DISKCOST=300000000
[KB958314ATLX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\ATL\vc_atlx86runtime.msi
[KB958314MFCX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\MFC\vc_mfcx86runtime.msi
[KB958314CRTX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\CRT\vc_crtx86runtime.msi
[KB958314OPENMPX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\OpenMP\vc_openmpx86runtime.msi
[KB958314ATLX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\ATL\vc_atlx64runtime.msi
[KB958314MFCX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\MFC\vc_mfcx64runtime.msi
[KB958314CRTX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\CRT\vc_crtx64runtime.msi
[KB958314OPENMPX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\OpenMP\vc_openmpx64runtime.msi
[IE7]
PRODUCT_NAME=Internet Explorer 7
PRODUCT_MESSAGE=SetupRes.dll;209
VC_FUNC=IeVerCheck
VC_DESCRIPTION=Detecting Internet Explorer 7
ACTION=INSTALL
EXE_PATH=NULL
#================================================= Autodesk tools ============================================================
[NLM]
PLATFORM=NATIVE
PRODUCT_NAME=Network License Manager
PRODUCT_MESSAGE=AcSetupRes.dll;47
LOG=%tmp%\NLM Install.log
EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi
EXE_PARAM=ALLUSERS=1
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
DISKCOST=8000000
#== Add more available languages
LPMODE=MLD_ADR
EULA_PATH=EULA
[CADM]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk CAD Manager Tools
PRODUCT_MESSAGE=AcSetupRes.dll;46
PREREQUISITE=SSE2
LOG=%tmp%\CADManager Install.log
EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
LPMODE=MLD_ADR
EULA_PATH=EULA
#================================================= 3rd Party tools ============================================================
[WORKFLOWS]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk Workflows 2014
LOG=%tmp%\Workflows 2014 Install.log
EXE_PATH=3rdParty\%platform%\Workflows\Workflow_%platform%.msi
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
#================================================= Common Autodesk Content ============================================================
[CM2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86
PRODUCT_NAME=Autodesk Material Library 2014
EXE_PATH=Content\ADSKMaterials\2014\CM\MaterialLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\CM\*.cab
ADMIN_INSTALL=NO
DISKCOST=88100000
EULA_PATH=eula
ACTION=INSTALL
[CMILB2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014
PRODUCT_NAME=Autodesk Material Library 2014 - Base Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILB\BaseImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILB.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILB\*.cab
ADMIN_INSTALL=NO
DISKCOST=82900000
EULA_PATH=eula
ACTION=INSTALL
[CMILL2014]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2014 - Low Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILL\LowImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILL.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILL\*.cab
ADMIN_INSTALL=NO
DISKCOST=258000000
EULA_PATH=eula
ACTION=INSTALL
[CMILM2014]
SHARED_COMPONENT=YES
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014;CMILB2014;CMILL2014
PRODUCT_NAME=Autodesk Material Library 2014 - Medium Image Library
PRODUCT_MESSAGE=AcSetupRes.dll;61
EXE_PATH=Content\ADSKMaterials\2014\ILM\MediumImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILM\*.cab
ROLLBACKABLE=YES
ALLOW_ADD_REMOVE=NO
ADMIN_INSTALL=NO
DISKCOST=762000000
EULA_PATH=eula
#== Uncomment the line below if you want it installed by default
ACTION=INSTALL
#================================================= Common Autodesk Components ============================================================
#================================================= 3rd Party Components ============================================================
#== Note about 3rdParty licenses:
#== If 3rdParty component licenses need to be included in the media, put them in 3rdParty\Licenses folder.
#== Taking the example of Revit Architecture:
#== RAC2012\3rdParty\Licenses\
#== - GNU
#== - Mozilla Public License
#== You may be required to ship the source code to the 3rd party components, for example QT (free license).
#== Put the source code in the 3rdParty\Source\[ComponentName{VerX.X}] folder. You must add a version number to the component so it does not conflict with other products.
#== For example:
#== RAC2012\3rdParty\Source\QT5.5\
[MSI4]
PLATFORM=ALL
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
[NLSDL]
PLATFORM=NATIVE
PRODUCT_NAME=Microsoft NLS Downlevel APIs
EXE_PATH=NLSDL\nlsdl.x86.exe
EXE64_PATH=NLSDL\nlsdl.amd64.exe
IGNORE_FAILURE=YES
#============= VCREDIST Begin ===============
#== Note about VCREDIST section names used:
#== The template uses a naming that matches the MSDN download name. It doesn’t use a version number.
#== For example, if you downloaded the package from http://www.microsoft.com/downloads/en/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&dis...
#== you would use [VCREDIST2008SP1X86] in the INI.
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart
VC_FUNC=VCx86RedisCheck
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
IGNORE_ERROR=5100
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
VC_FUNC=VCx64RedisCheck
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
IGNORE_ERROR=5100
[VCREDIST2008SP1X86_6161]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161
EXE_PATH=3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={9BE518E6-ECC6-35A9-88E4-87755C07200F}
[VCREDIST2008SP1X64_6161]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}
PLATFORM=ALL
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
[VCREDIST2008SP1X64]
PLATFORM=x64
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" "
VC_PARAM={837b34e3-7c30-493c-8f6a-2b0f04e2912c}
[VCREDIST2005SP1ATLX64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" "
VC_PARAM={6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}
[VCREDIST2005X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005\vcredist_x86.exe
VC_PARAM={7299052B-02A4-4627-81F2-1818DA5D550D}
[VCREDIST2005X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005\vcredist_x64.exe
VC_PARAM={071C9B48-7C32-4621-A0AC-3F809523288F}
#============= VCREDIST End ===============
[SSE2]
PRODUCT_NAME=SSE2 Support Check
PRODUCT_MESSAGE=SSE2 Support Check
EXE_PATH=NULL
VC_FUNC=CheckForSSE2Support
VC_DESCRIPTION=SSE2 Support Check
#============= DOTNET Begin ===============
[DOTNET45]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4.5
VC_DESCRIPTION=Detecting .NET 4.5 Runtime
DISKCOST=816640000
[DOTNET45LANG]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5 Language pack
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45LP_Full_x86_x64_%lcid%.exe
AVAILABLELANGUAGES=1025;1028;1029;1030;1031;1032;1035;1036;1037;1038;1040;1041;1042;1044;1045;1046;1049;1053;1055;2052;2070;3082
VC_FUNC=DotnetLangPacksVerCheck
VC_PARAM=%lcid%;4.5.50709
LPMODE=MLD_ADR
IGNORE_LANGS=1033
IGNORE_FAILURE=YES
DISKCOST=3000000
[_DOTNET35SP1]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 3.5 SP1
EXE_PATH=3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe
VC_PARAM=.NET Framework 3.5 SP1
VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1
DISKCOST=80000000
IGNORE_FAILURE=NO
#============= DOTNET End ===============
[DIRECTX]
PLATFORM=ALL
PREREQUISITE=_DOTNET35SP1
PRODUCT_NAME=DirectX® Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
[FaroSDK]
PLATFORM=NATIVE
PRODUCT_NAME=FaroSDK
EXE_PATH=3rdParty\%platform%\FaroSDK\FARO.LS_5.1.0.30630.msi
LOG="%tmp%\FaroSDK.log"
ACTION=INSTALL
IGNORE_FAILURE=YES
#==================== Common Main Pages: Install Mode
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#==================== Common Main Pages: Deploy Mode
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#==================== Common Config pages: Install Mode
[InstallTypePage]
UI_CREATOR=InstallTypePage
[RevitContentPackPanel]
UI_CREATOR=ContentPackPage
UI_SOURCE=Setup\RevitContentPackUI.dll
[RevitConfigFolderPanel]
UI_CREATOR=ConfigFolderPage
[DisciplinePage]
UI_CREATOR=RevitDisciplinePanel
[UKResPage]
UI_CREATOR=RevitUKResPanel
#==================== Common Config Pages: Deploy Mode
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
UI_POSTCONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_POSTCONSTRUCT=OnlineResourcesPostConstruct
[RevitSettingsPage]
UI_CREATOR=RevitSettingsPanel
#==================== Common Main Pages: Maintenance Mode
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
#== This is from AEC - Revit, Civil 3D
[RevitContentPackDialog]
UI_CREATOR=ContentPackDialog
[AddAddonPage]
UI_CREATOR=AddAddonPage
Administrator Productivity
