Installation & Licensing
New Member
The_Goob
Message 1 of 2 (524 Views)
Installing Revit 2014 hanging at preparing, Revit downloaded Library didn't
524 Views, 1 Replies
03-02-2014 07:46 PM
I have autocad 2014, and trying to install revit to complete drafting homework at home. It failed so I kept trying, eventually the main program installed, but not the English Library pack, and so when I run Revit, it loads and never opens. I have tried re-running the install but it always fails. i click retry multiple times and eventually it just flat out stops. I have un-installed and re-installed multiple times.
Distinguished Mentor
JoAnn_Hogan
Message 2 of 2 (508 Views)
Re: Installing Revit 2014 hanging at preparing, Revit downloaded Library didn't
03-03-2014 12:52 AM in reply to: The_Goob
HI There
Welcome to the community,
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Announcements
Need installation help?
