Installation & Licensing
Installing MDT 2009 with Inventor 2012 Product Design Suite
1 REPLY 1
tehjosheh
662 Views, 1 Reply
I am having a problem installing MDT 2009 on my machine with an existing Inventor 2012 license.
I run into a "fatal fault" which, by the log file, is due to reason "1603".
I have tried everything here:
http://forums.autodesk.com/t5/Installation-Licensing/MDT2009-install/td-p/3131470
That is, i'm using the latest installer, there are no previous directories installed, and i made sure to unzip both disks in the same folder.
Attached is the larger log from my failed installation.
Any help would be MUCH appreciated.
Josh
1 REPLY 1
TravisNave
in reply to: tehjosheh
You've download the last version of MDT 2009 from here?
http://usa.autodesk.com/adsk/servlet/pc/item?id=13744274&siteID=123112
1603 is pretty generic.  You do realize this program is no longer supported and has been retired, right?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
