Installation & Licensing
New Member
tehjosheh
Message 1 of 2 (434 Views)
Installing MDT 2009 with Inventor 2012 Product Design Suite
434 Views, 1 Replies
05-16-2012 04:28 PM
I am having a problem installing MDT 2009 on my machine with an existing Inventor 2012 license.
I run into a "fatal fault" which, by the log file, is due to reason "1603".
I have tried everything here:
http://forums.autodesk.com/t5/Installation-Licensing/MDT2009-install/td-p/3131470
That is, i'm using the latest installer, there are no previous directories installed, and i made sure to unzip both disks in the same folder.
Attached is the larger log from my failed installation.
Any help would be MUCH appreciated.
Josh
TravisNave
Message 2 of 2 (418 Views)
Re: Installing MDT 2009 with Inventor 2012 Product Design Suite
05-17-2012 10:15 AM in reply to: tehjosheh
You've download the last version of MDT 2009 from here?
http://usa.autodesk.com/adsk/servlet/pc/item?id=13744274&siteID=123112
1603 is pretty generic.  You do realize this program is no longer supported and has been retired, right?
