Installation & Licensing
Member
0 Kudos
Post 1 of 7
installing Maya 2014 SP3
490 Views, 6 Replies
12-29-2013 04:38 PM
How do I verify that SP3 is installed?  When I go to Main Menu>Help>About Maya, I do not see any reference to SP3 in the name of the version.
Sean
Product Support
26 Kudos
Post 2 of 7
Re: installing Maya 2014 SP3
12-30-2013 11:59 PM in reply to: sean_rodrigues
Tony Su
Member
0 Kudos
Post 3 of 7
12-31-2013 03:40 PM in reply to: tony.su
Hello Tony, that is what I was expecting to see, but mine does not show the SP3.  Attached is a screen grab of what I see after installing the SP3.
Sean
Product Support
26 Kudos
Post 4 of 7
01-01-2014 06:18 PM in reply to: sean_rodrigues
Do you see cut ID? Your maya released in 2013.3, so it isn't sp3.
Download from here -
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22443097&linkID=9242259
Tony Su
Member
0 Kudos
Post 5 of 7
01-02-2014 09:14 PM in reply to: tony.su
I had an upgrade to Maya 2014.  I clicked on the link you gave me and downloaded Autodesk_Maya_2014_SP3_English_Japanese_SimplifiedChinese_Win_64bit.sfx(1)
It only installed the Backburner, it did not install anyother patches.  Was that the correct link to download the patch for Maya 2014 SP3?
Sean
Product Support
26 Kudos
Post 6 of 7
01-02-2014 10:06 PM in reply to: sean_rodrigues
the correct file is Autodesk_Maya_2014_SP3_English_Linux_64bit.tgz
you can find in http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22443097&linkID=9242259
But you need uninstall Maya 2014 first, or you will see "installed" when you install Maya.
This is how-to uninstall Maya on linux:
http://help.autodesk.com/view/INSTALL_LICENSE/2014/ENU/?guid=GUID-28DA8922-C1D0-406C-B7FA-8FBB99D10E...
Tony Su
Member
0 Kudos
Post 7 of 7
01-07-2014 07:53 PM in reply to: tony.su
I have a PC, do I have to uninstall the old Maya 2014, then install the new Maya 2014 SP3?  I ask this because I can not find my install for Maya 2014.  I don't want to loose my Maya 2014.
Sean
