Jerry wrote:
> Mark,
> Thanks for the info, this is the first time I'm responsible for the upgrade
> You will obviously need to merge the license file on the FLEXlm
> server though.
> Can you elaborate on merging the license files.
> Do I need to install Inventor on the server or can I just install it from
> the CD at each of the clients.
Hi Jerry,
I was thinking a bit further on this. There might be an aspect of the license agreement that you
have to be careful with here.
The original version of MDT6 you have uses the original version of the FLEXlm license file. The
version you have with the Inventor series uses a new FLEXlm license file. Technically you have to
"dispose" of your original MDT license based on the license agreement, *but* I think this would only
apply if you have upgraded the MDT6 to the Inventor Series. In summary, if you have upgraded the
MDT6 to the Inventor series let me know and I can investigate.
Merging/combining the license file is best described at the following solution:
http://support.autodesk.com/getdoc.asp?id=TS65928
I am not sure on Inventor deployments so will need to check and get back to you on this, but please
let me know if you solve this in the mean time.
Mark Taylor
Product Support, EMEA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
