Solved by asburyj. Go to Solution.
Extract the files to your C:\ drive and install from there.
This can happen when trying to run the installer of of external flash memory like a USB stick/SD card. Unfortunately you will need to copy the installer locally. Another alternative is if you have a full portable hard drive (not a USB thumb drive) it will usually not have any problem installing from those.
