Installation & Licensing
Installing Inventor 2012 Pro - WSE 3.0 Issue?
1 REPLY 1
clafont
253 Views, 1 Reply
When installing, it pops up that it is looking for the WSE 3.0 file which is on another disk.  I'm using the USB from Autodesk to install.  I've already installed WSE 3.0 but it still seems to be looking for it and errors out.  It then closes the installation.  Anyone ran into this?
1 REPLY 1
TravisNave
in reply to: clafont
Copying all the contents from the media to a single folder on the HDD and installing from there usually resolves issues like this.  In many cases, if you install the prerequisites first, the Autodesk installer will also skip them.  You might consider that as well.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
