Installation & Licensing
Installing individual products from Suite product
2 REPLIES 2
Jroper
368 Views, 2 Replies
What do we need in order to install a single product from a Suite product?
For instance, say I would like only to copy over just the Navisworks Manage 64 bit portion of the Building Design Suite Ultimate installation.  Could I simply copy the folder ...\AdminImage\x64\NAVMAN folder?  Does it have all the necessary components for installation?
2 REPLIES 2
TravisNave
in reply to: Jroper
Unlikely.  Just create a deployment with only that product selected and it will only install that product.  That should be the easiest.
Autodesk Forums:
Jroper
in reply to: TravisNave
Installed Navisworks Manage from a Building Design Suite product by going into the NAVMAN folder and using the roamer.msi.
But I was not able to launch Revit Structure in the same way with the RST2012.msi in its folder.  It gave me a 1604 error.
So it's hit a miss.  Creating single deployments should be the way to go.  Thanks.
Administrator Productivity
