hi,
many times i have tried to install the autodesk inventor 2012 student version but it gives the same error over and over again.
So i installed the MaterialLibrary and if i look at the installed software it is installed but i still get the error...
I tried:
- installing safemode
- new user acc with admin rights
- uninstalled all MS C++ 2010 programs
- re installing material library many times
- uninstalled all autodesk products ( had inventor 2009 student version before..)
I really dont know what to do and didn't find others with this problem..
it seems so that the material library is installed but that the installer does not see it is.
i hope some one can and wil help me with this, for the setup log see the attachment.
Make sure that all of your old Inventor files, material libraries, and content centers are uninstalled first.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
There was nothing of autodesk installed and nothing in the registers still the same error as seen in the first picture.
used windows clean instal program also same error.
Manually installing the material library does work, but the installer does not see that the library is installed that is the problem.I really dont want to install clean windows, but dont know how to solve it otherwise....
I am having the same error, I do not know what to do, I tried the same and I still I have this error message, please, I need help, I really need to install Autodesk to work.
Sorry to say but I tried a few more times but so far nothing worked, can’t understand why.
The library manually installing worked but the installer just won’t see it is installed or it is not correctly installed.
So i also still don't have any sullution, hope that some one does...
I've been trying to install Revit Architecture 2012 but i got the same error. I attached the installation log File, may be with this log you can help us.
Regards!
