Is there a way to install LT 2014 without Autodesk 360? I can de-select the option in install config, but it still installs and places a shortcut on the desktop. It seems to install during the step "AutoDesk Cloud Sync".
I can uninstall 360 afterwards, but this isn't really a great workaround.
Cheers,
Az.
Solved by JTBWorld. Go to Solution.
you would have to edit the setup.ini in some way would be the only other way i can think of
DarrenP
Change the below line in the ini file is the only option unless you uninstall 360 after:
POSTREQUISITE=ACAD_PSPACK;ADSYNC;ACADSKETCHUPIMPORT
to
POSTREQUISITE=ACAD_PSPACK;ACADSKETCHUPIMPORT
I've also documented the problem here.
i'm not been running without it for a few months
DarrenP
